Who here has installed a bypass for the factory lift pump???
Old Jun 6, 2005 | 03:22 PM
big red psd cc's Avatar
Need to who know who has installed an adaptor or something so that I can get rid of the factory lift pump and run just the Holley Blue as the sole pump?
Thanks.
Old Jun 6, 2005 | 03:39 PM
TRAVIST's Avatar
04.5 Does not have the lift pump. They went to an intake pump on the 04.5 models trucks.
TRAVIST
Old Jun 6, 2005 | 04:00 PM
Well you know what I mean. Actually their true name is a "Transfer Pump.
Either way its that Piece of Junk on the side of the fuel filter housing.
Old Jun 6, 2005 | 04:27 PM
Mcmopar's Avatar
Not on your truck!
Old Jun 6, 2005 | 04:30 PM
TRAVIST's Avatar
The 04.5 does not have the pump in the filter housing. As a matter of fact when replacing the transfer pump on the 03-04 you have to convert it to an in-tank pump using new part numbers. So the pump that you are talking about you do not have because it is part of the fuel module in the tank. I see that you work at a dodge dealer, check with your parts guys. I also work in parts at a dealership.
TRAVIST
Old Jun 6, 2005 | 05:35 PM
DR3500's Avatar
I was under the impression that the '04.5 bstill had the pump in the filter. the '05 are the first to get the in-tank pump.
Old Jun 6, 2005 | 07:32 PM
OH YES I DO!!!!!!!!!
DR500 you are correct. The 2005 have the in-tank pumps.
Its right there....on the filter housing.
Thats why I want to get rid of it!!!!!
Its the 2nd one in 32K miles.
Now.....the pump itself is now being superceded.......with the 2005 style in-take pump.
Old Jun 6, 2005 | 08:33 PM
triplenickel's Avatar
I haven't but lots of people have, a search should get you all the info you can digest. If you get ahold of Scotty here he builds an adapter for when you remove the stocker from the filter housing.
Old Jun 6, 2005 | 08:51 PM
I left Scotty a message on his phone. Waiting for his call.
Old Jun 6, 2005 | 10:46 PM
yycguy's Avatar
I recently contacted Scotty reference a bypass for the stock lift pump and the Holly blue pump. What he told me was that he no longer uses a bypass and instead just installs the holly in-line. I maybe mistaken but I believe that was the idea.
I am sure Scotty will chime in if he sees this thread
Old Jun 6, 2005 | 11:52 PM
Scotty's Avatar
Top's Younger Twin
I discontinued the adapter for two reasons.
Several folks where reporting to me they had great fuel pressures and no problems with upwards of 80,000 miles running the two pumps. There are a few folks on this site running Holley blues or reds with their stock pumps.
The other reason I canned the adapter is because the machinist was unable to maintain the tolerances after MANY attempts.
I even tried to get the adapter Dodge makes for the in tank option but they will not sell it seperately.
When did you leave me a voicemail?
Scotty
The_Head
Apr 30, 2011 10:30 PM
Ram Daddy
Sep 24, 2008 03:45 PM
Leon441
Jun 23, 2006 07:20 PM
evan4434
Jan 9, 2006 05:00 AM
Mark Thomas
Apr 29, 2005 11:52 AM
