Has anyone here ever outrun a LP piston lift pump?
What I mean is, have you pulled your fuel pressure down low when running a low pressure lift pump?
I was curious to know if it's happened to anybody. What were the details of your setup when this happened?
Correct.
Digging through past threads, I found that my experience was . . . .
With the regular piston lift-pump, 3/8"ID plumbing and a big fuel filter, running PDR "190" injectors with the typically tweaked injection pump, I'm seeing . ..
- Approximately 12psig while free-revving the engine to 2500rpm.
- Approximately 9psig at idle.
- Approximately 7psig under WOT.
That is what mine is doing with the diaphragm pump now. With all you got going on you probably are. Time to dig back through the threads and look at the high volume converted to low pressure pump or go electric.
What are you running now? I was thinking about an Airdog 100 or 150 for a 24 valve application. I think I remember reading they are regulated to the same pressure as what out injection pump needs.
