whats the best chip/programmer for an 06??
Old Mar 30, 2008 | 06:27 PM
mx684's Avatar
a buddy of mine is converting from a powerstroke to an 06 dodge....he called me wondering what would be the best chip for his truck....he uses is to tow 10,000-12,000 quite often...i dont really know anything about the common rail motors, so i was wondering what you guys reccomended for it. again, mainly for towing, but it wouldnt hurt to be able to turn it up to have a little fun...
from the little i have read about common rails it seems i have seen more mentioned about quad products or smarty than anything.....he just doesnt wanna go to small and wish he woulda got sumthing bigger....
also, this truck should come factory with 4" exhaust, is that correct? so i dont imagine an exhaust upgrade is real important as it is on a 24valve..am i correct on this? thanks guys..
Old Mar 30, 2008 | 06:32 PM
james98&1/2's Avatar
not sure on the exhaust but i do know a Smarty will wake that truck up
Old Mar 30, 2008 | 07:22 PM
mx684's Avatar
so 1 vote smarty...
Old Mar 30, 2008 | 07:43 PM
ShutupAndHoldOn's Avatar
The Smarty or Smarty Jr. is awesome. You can also swap out the muffler for a straight though one ( I put on a Magnaflow direct fit in 20 minutes). It seems to help with EGT but not much differnce on power. I tow a 15,000lbs fifth wheel in the mountains not problem.
Old Mar 30, 2008 | 07:55 PM
Boz007's Avatar
Smarty here.
Old Mar 30, 2008 | 07:58 PM
06RAM2500's Avatar
Smarty Sr or Jr. They're currently working on new s/w for the Sr. Check it out!
http://madselectronics.com/SmartyREVO.html
Old Mar 30, 2008 | 08:00 PM
mx684's Avatar
well it sounds like the smarty is the way to go...thanks alot guys, i appreciate it.
Old Mar 30, 2008 | 08:38 PM
rattlbox's Avatar
smarty and the factory exhaust is 4 inch.
Old Mar 31, 2008 | 07:10 PM
mx684's Avatar
forgot to ask...does the smarty do boost fooling or would he need to get a boost fooler also???
Old Mar 31, 2008 | 10:07 PM
kuhkuhkyle's Avatar
he can either download the aftermarket turbo software, or he can buy a quad boost fooler. I'm running the quad now, but once my harness for the MP8 gets here, i'll be running the aftermarket turbo software.
Old Mar 31, 2008 | 11:04 PM
omaharam's Avatar
Smarty = most power with coolest egts.
That is step 3 however.
Step 1 is gauges - at very minimum an egt gauge
Step 2 is either a clutch or upgrades to the 48re if an auto.
He can runner lower settings on the Smarty with the stock tranny, but if he's anything like me, he wont' be able to resist the temptation to load the higher power settings and then he is playing with fire with a stock auto or clutch.
Old Apr 1, 2008 | 01:14 AM
LVTony's Avatar
06 is a 4" exhaust, but the stock muffler must be removed/replaced. Either go straight pipe or a straight through muffler.
Smarty rocks. Gauges needed. Then a tranny/clutch.
Old Apr 1, 2008 | 01:50 AM
Kman9090's Avatar
You could look through the classafieds and see what they have. The Smarty is a good chip but he is gonna need gauges also. You might be able to find the bully dog with out look monitor for 500 bucks.
Old Apr 1, 2008 | 07:49 PM
mx684's Avatar
thanks alot for the info guys! he is going to order guages first thing....his is a standard, so i will tell him he needs to think about a clutch, and might want to get a quad boost fooler...thanks again guys!
Dodge5.9
Nov 11, 2006 01:27 AM
hyunsinsone
Oct 10, 2006 05:54 PM
hyunsinsone
15
Oct 6, 2006 04:53 PM
hyunsinsone
Oct 4, 2006 03:43 PM
G-NOTE
13
Aug 16, 2005 02:03 PM
