what upgrades to hold crazy larry?
ok on my 06 dually what upgrades do i need to run the crazy larry on my truck??
will there be any long term affects??
im currently running the 90hp triple dog setting..5" turbo back exhaust..and aem intake....
if i want to run the 130 pref the 230hp crazy larry daily..what will need to be changed??
how much of a diff will i be overall?
I would think a new turbo and fuel pump would be necessary for reliable performance.
Do you have an auto or 6-spd? You'll need a clutch with the 6-spd and some major tranny work with the auto.
Soem others will chime in, but I think that's what you'd need to run it for any period of time.
you need the version 2.2.2 if u have that it will work. and if it is is a auto do a torque converter,valve body,flex plate,and a billet input shaft. www.atsdiesel.com and if it is a st do a cluch
i have a 06 with the crazy larry downlaod on it and now i dont have a tranny in it
I've been giving my truck hell for 10,000miles with it on the CL program. I run 35" tires, I've been mudding, racing, blow d-nuts, you name it, so far its held up okay. I got stock air intake and a gutted stock exhaust. But maybe I'm just lucky, I dkn. Only thing I notice is my egt's climb pretty fast, but only way to fix that is a $6000 twin turbo system.
But if you have the $$ to spend, I would go new tranny, torque convertor, fuel pump, injectors and twin turbo, then you can stack the CL and have MONSTER power.
Hey PG you can get a great spooling single turbo for all around daily use and playing, for a lot less than twins and still drop egt's considerably. Just look into Industrial Injection's Phat Shaft turbos, HTT's HB series turbos, or even a B1, B2, BD Super B or any of the upgraded Schwietzer300 series turbos from many different vendors.
id get guages first, (dont know if u have any)and its a big difference between the performance and crazzy larry + alot of smoke and it only 180hp, the 230 is for the durawacker
my good friend (blackdevil) needed a new clutch after ~5 months on the performance program. i think the only time he ran CL was when we installed the outlook and BDDL. he's got a dual disc McLeod on there which works much better apparently...
regards,
chase
regards,
chase
MOJO1
18
03-23-2016 06:47 PM
smoky05
22
11-30-2007 08:26 PM
huntingdeer
09-17-2007 09:34 PM
HeberRam
03-30-2007 05:37 PM
Snojumper
34
03-18-2007 12:27 PM
