crazy larry or scarry larry
Old Nov 25, 2007 | 09:20 PM
smoky05's Avatar
i have heard some guys talking about crazy larry and scary larry. whats the difference? are they the same? i have the cl now but if the sl is faster i want it.
Old Nov 25, 2007 | 09:28 PM
rustyshakelford's Avatar
scary larry is nasty. it requires serious mods to be utilized. its difficult to acquire
brett
Old Nov 25, 2007 | 09:50 PM
trefling's Avatar
It's the crazzy larry w/o torque management.
Old Nov 26, 2007 | 02:15 PM
nope. its a completely different program. i cant remember whats its rated for, but its alot and works the best on 05 autos.
brett
Old Nov 26, 2007 | 02:49 PM
CReed's Avatar
Scary larry is custom tune built by bud kunz for a 05 auto and the tune made its way out to the public when it wasnt suppose too. It has serious amounts of timing and duration and works well with the use of a pressure box. Studs are needed with aftermarket turbo and definetly a transmission with fuel supporting mods as well. Crazy larry 2.4.1 has the same exact fueling curve as the old scary larry 2.2.7 but the tsb's are way different and you cant get as much out of the trucks that require this newer tsb. A few members on here along with myself have the old 2.2.7 file but its a play at your own risk type deal and most won't release it too anyone without a few supporting mods.
Old Nov 26, 2007 | 03:34 PM
Rpainter's Avatar
way to straighten them out Chris
Old Nov 26, 2007 | 03:35 PM
Rpainter's Avatar
you truck is not ready for scarry larry yet
Old Nov 26, 2007 | 04:02 PM
RAT_03's Avatar
DTR's "Secret Agent"
i love the scarry larry
Old Nov 26, 2007 | 09:41 PM
smoky05's Avatar
what else do i need to run the scarry larry?
Old Nov 26, 2007 | 09:56 PM
CReed's Avatar
Turbo and manifold 62mm or bigger to keep things cool, head studs will be needed seeing how this program makes alot of cylinder pressures and will blow head gasket easily. Exhaust system, Cold air intake, aftermarket lift pump such as a glacier, fass, or airdog, etc. And if injectors are modified a
cp3 pump. A built transmission either FE or dual disc, or fully built auto.
Old Nov 26, 2007 | 10:00 PM
CrashCade's Avatar
That kind of sums it all up. This is a very true statement. I would definitely make sure you have the tranny done and atleast head studs, but if you run it hard enough you will definitely damage something.
Old Nov 26, 2007 | 11:42 PM
trefling's Avatar
brett
That's just what I was told by both PDI guys and a bullydog tech. Maybe I"m wrong, regardless it's stilll crazzy fast. If you don't have fuel mods you'll throw a low pressure light/code fast
Old Nov 27, 2007 | 12:24 AM
CBD05's Avatar
i wanted it but im just not ready yet. maybe in a year or so. trannyfirst for me. thats what i need.
Old Nov 27, 2007 | 05:52 PM
nathan04's Avatar
I've been running scarry larry stacked with mp-8 for about 4 months. I have stock turbo, fuel system, cp3, etc. 4WD 20 psi boosted launches and never had any issues(knock on wood)
Old Nov 27, 2007 | 06:01 PM
Rpainter's Avatar
I willing to bet if you stick a rail pressure gauge on that truck you will find out that you are draining the rail fast and not getting half the power scarry larry is capable of. and stock turbo can not push nearly enough air to keep egts under control but hey it is your motor
