Sponsored by:
Sponsored by: DashLynx
what mod for towing
Old 12-20-2008, 10:21 PM
rich's Avatar
what mod for towing
i would like to put a mild power increase on my truck that will do the least amount of increasing my rail pressure that is being used by someone who tows heavy and a lot. heavy means over 16k includes trailer and freight and does it about 80% of the time. 06 g56
Old 12-21-2008, 12:06 AM
Sam Turner2's Avatar
I run my truck as listed, I tow well over 16K regularly, I have had the quad box (it is a pressure box) and ran it on 60HP while towing for a little over 50K miles with no problems. I put about 45% miles with a 5K empty trailer and 45% with anywhere from 15K to 25K. The other 10% is around town, ect.
Old 12-21-2008, 12:19 AM
98whitelightnin's Avatar
I also have the quad xzilleraider and run it on 60hp all the time. It pulls good and egt's are not a problem.
Old 12-21-2008, 12:20 AM
alboy's Avatar
I have been very happy with my Edge/att.i believe this is mostly a timing box,increases injection events,tow at 23000 lbs gross on the 40 hp setting,lots of power,also comes with a guage pod etc,35000 miles and no issues.
Old 12-21-2008, 03:05 AM
White97GTVert's Avatar
You will want a programmer that doesn't do rail pressure by default, or an Edge/Attitude (no pressure added).
If you are wanting to avoid pressure, don't get a Quadzilla box. They are good, but that is their primary way of adding power and you said you don't want pressure.
TST Is another option, but depends on your build date whether you can run it or not.
Being that you are towing heavy, I'd vote against the Edge since EGT's are a common complaint. I know it was very high EGT's when I had it on my 05. Go with a decent programmer. Browse the forums and see what everybody is running. You'll know what to get.
Old 12-21-2008, 07:44 AM
UNDER-PRESSURE's Avatar
Thumbs up
I've been very happy with the Dr. Performance modules but they do add some rail pressure.
Old 12-21-2008, 11:26 AM
Spooler's Avatar
Smarty Jr. is what you need and a set of gauges. Edge Juice runs just way too hot. You can't use that power at all towing heavy. You will have more of a chance to use that additional power with the Smarty Jr.
Old 12-21-2008, 12:03 PM
rip 112's Avatar
After reading everything said so far, I'd have to agree with Spooler. I think the Smarty Jr would be the best bang for the buck and best candidate for what you want.
Old 12-21-2008, 01:11 PM
MTC
MTC's Avatar
Another vote for the Smarty Jr. The power is awesome and the EGT's are definately cooler.
Old 12-21-2008, 01:26 PM
dodchall70's Avatar
I agree. Good power and the Smarty Jr. lowered my EGT's lower than stock.
Old 12-21-2008, 04:31 PM
chadder1313's Avatar
I love my Edge. I have zero complaints.
Old 12-21-2008, 09:07 PM
buralcat's Avatar
my edge runs a little hot but only when i am pulling a really big grade. keep in mind you can always change the edge on the fly (not sure you can do that on the smarty), if i know i am going into the mountains i just turn it down with no problems.
Old 12-21-2008, 09:26 PM
txfiremedic's Avatar
Edge/Attitude. Safe and comes with Gauges which is a MUST HAVE!!
Old 12-21-2008, 09:30 PM
metalbasher's Avatar
Smarty jr. and gauges all the way
Kenworth
07-15-2008 04:18 PM
jmccart
12-19-2007 12:49 AM
jamesbfishin
07-07-2007 08:25 PM
wap
14
04-23-2007 06:46 PM
RAMV
07-14-2004 12:08 PM
Quick Reply: what mod for towing
