What exactly is a boost fooler and do I need one?
Old Aug 9, 2007 | 10:24 AM
VikingDiesel's Avatar
Dont really understand what it does. It gives you more boost??? Why is it so cheap anyways, only like $50 or so.
Old Aug 9, 2007 | 10:38 AM
JD Dearden's Avatar
If your truck makes to much booosht than your engine dosent like it and it defuels, the fooler makes the engine think its not, tricky tricky. I dident notice my truck doin it until I was over 50 pounds, I was pullin my boat and went to pass a semi and mashed it than the defueling started it was kindoff scary since there was a car coming.
Old Aug 9, 2007 | 11:03 AM
so I should definetly get this? Easy to install? How much more power will I get out of this?
Old Aug 9, 2007 | 11:11 AM
JD Dearden's Avatar
i have no idea and a truck setup like your but i suppose it couldent hurt, you just have to splice it in
Old Aug 9, 2007 | 11:15 AM
AggieJustin's Avatar
Doesn't the Juice take care of the boost fooling function for you? If so, you don't need another box to do it.
Old Aug 9, 2007 | 11:18 AM
duranator06's Avatar
The edge juice should do boost fooling. mine did at least
Old Aug 9, 2007 | 11:22 AM
Truckman0097's Avatar
Some boxes do fooling themselves and this would not be needed... however, I was under the impression that these are plug and play - no splicing required for newer trucks?? Or maybe it depends on the brand fooler you get? Anyone know for sure?
Old Aug 9, 2007 | 11:23 AM
JD Dearden's Avatar
Mine is spliced in.
Old Aug 9, 2007 | 11:27 AM
If I am not mistaken Quad makes one that plugs right in to the map sensor and itis onlylike $75
Old Aug 9, 2007 | 11:48 AM
so another words, just turn DE-FUELING off?
Killdmycobra
Nov 12, 2010 05:15 PM
One Way
25
Jun 23, 2009 11:16 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
SilverHoss99
Aug 25, 2006 05:02 PM
GTSDave
Jul 8, 2005 09:06 AM
