Water pump
Old Jun 2, 2010 | 09:45 AM
AlCorr's Avatar
Water pump
Can anyone tell me how long they are go for (miles). I have a little over 100,000 on the clock. I'm talking daily driven trucks that tow on weekend. Not you drag racing or sled pulling trucks.
Old Jun 2, 2010 | 10:00 AM
RTillery's Avatar
I changed mine out at 200k and it was still ok. It was not leaking but I could tell the bearings and seals were looser than the new one! (Bosch from Rock Auto)
Old Jun 2, 2010 | 11:40 AM
jballou's Avatar
Mine went at 50k, others much more miles, you just never know, keep the tools and one with you if concerned.
Old Jun 2, 2010 | 12:35 PM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I have 187K and no issues, I'm not changing it just because of high miles, if it aint broke I aint fixing it. Keep the coolant clean and air free.
Old Jun 2, 2010 | 02:37 PM
Fishguy 50's Avatar
Coolant pump went out at 250k on the 00, still ok at 110k on 05. These pumps are easy to change, an easy road side fix if you had to.
Old Jun 2, 2010 | 05:25 PM
DodgeDiesel61's Avatar
We just changed the water pump in my boss's '97 are are fairly certain it was the original (same Cummins Bluke color and part #).
Started leaking out the weep-hole at 310,000
Old Jun 2, 2010 | 05:45 PM
ataboy9026's Avatar
mine lasted about 95k. There was play in the bearing.
Old Jun 3, 2010 | 08:38 AM
dodchall70's Avatar
Had do replace mine at 65,000. Easy to do though. The hardest part was removing the belt.
Old Jun 3, 2010 | 12:45 PM
rufushusky's Avatar
Mine is still working fine at 193k miles.
Old Jun 3, 2010 | 04:22 PM
bigjohn04's Avatar
Just over 150,000 when mine started weeping. Put on an AC Delco since it had the same waranty as a Cummins pump for half the cost.
Old Jun 3, 2010 | 05:19 PM
bigblue1ton's Avatar
changed at 65,000 leaking from the weep hole
Old Jun 6, 2010 | 09:21 AM
5POINT9's Avatar
Changed at 70k AND 140k. Seems to be a trend for me? The second one just let go, complete slop when I took it apart. Then again, what do you expect from this crap made in China?
Old Jun 6, 2010 | 07:38 PM
Mexstan's Avatar
By the time I had 110,000 miles on the engine I had already changed two pumps. Both had no leaks and suddenly gushed water everywhere. I now carry a rebuilt pump with me at all times. Got it from Rock Auto for $60.
Old Jun 6, 2010 | 08:31 PM
johnh's Avatar
235000 and no signs of trouble,but i have one behind the seat
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
