Water Injection
Old Aug 21, 2009 | 11:55 AM
  #196
mopardamo's Avatar
Hello,
I have heard no talk about cylinder wash down from the water. When lube is stripped from the walls the temps start climbing and wear goes way up.
Damon
Old Aug 21, 2009 | 12:39 PM
  #197
TexasCTD's Avatar
Originally Posted by John_P
TexasCTD:
The "vacation" is for thirty (30) days right now. If Ace wants to come back at that point and conduct himself accordingly that will be fine. If not, that is fine too. Hope that helps.
Thanks John....just curious how that worked. I also didn't know, for example, if he knew at the time of his "banning".....that it was for 30 days only and after that point could rejoin the group. If he isn't aware of it, I would assume he thinks it's forever. And who knows if he even wants to come back. I am just asking hypothetically....since I don't know him.
BSwope...........sorry for the thread jack.
Old Aug 21, 2009 | 12:49 PM
  #198
CamperAndy's Avatar
Originally Posted by mopardamo
Hello,
I have hear no talk about cylinder wash down from the water. When lube is stripped from the walls the temps start climbing and wear goes way up.
Damon
Why do you see this as an issue? I do not think you will get any loss of wall oil film from water injection as long as the cross hatch is still intact.
Old Aug 21, 2009 | 02:21 PM
  #199
XLR8R's Avatar
The water isn't pressure-washing the cross-hatches... it's exhausted along with the other combustion byproducts.
Old Aug 21, 2009 | 04:58 PM
  #200
Bswope's Avatar
I got #200!!
Anyway anyone have any pics of there install or where you placed your nozzels?
Hopefully Ill get to my install here soon, but Id really like to meet up with Rpainter for a chat before I do...
BTW.... thanks for all the great info fellas!
Old Aug 21, 2009 | 08:09 PM
  #201
mikmaze's Avatar
left to right ports : boost reference for snow controler, 625 nozzle, 625 nozzle, and boost gauge hookup.
intakefromabove.jpg?t=1250903286
Old Aug 21, 2009 | 08:41 PM
  #202
Rpainter's Avatar
Originally Posted by Bswope
I got #200!!
hollar at me sometime and we can talk if you are in the area you can look Rob
Old Aug 21, 2009 | 09:32 PM
  #203
RowJ's Avatar
....... anyone have any pics of there install or where you placed your nozzels?
2nd Gen Pic...but placement is same for 3rd Gens!
Near to far - Eng Boost.... Snow's Stage II Controller Boost Sensor.... Two 625ml Injection nozzles.
EDIT: Newer set up Pic, with LazarSmith SS air Horn HERE
RJ
Old Aug 22, 2009 | 04:08 PM
  #204
doug60's Avatar
Here's a few picks
Nozzel location / Wilson Intake
1 - 14 GPM in the intake horn
1 - 7 GPM near #1 cylinder
1 - 7 GPM near #5 & 6
http://picasaweb.google.com/dquicksi...eat=directlink
Old Aug 22, 2009 | 06:04 PM
  #205
CamperAndy's Avatar
You must mean GPH, you will not shove 28 GPM into the engine using 1/4" tubing unless you are running MASSIVE pressure levels.
Old Aug 22, 2009 | 08:00 PM
  #206
doug60's Avatar
My bad
Sorry typo.
Old Aug 22, 2009 | 08:50 PM
  #207
mopardamo's Avatar
Hello,
Pretty obvious it's not pressure washing the cylinder walls. In gas motors an overly rich mixture can cause the oil film to break down and the ring seal goes south real quick. With the amount of water they are talking I can only believe that this is a very real concern. It would be interesting to see leak down tests before running water injection like what has been talked about and then a few months later.
Damon
Old Aug 23, 2009 | 08:43 AM
  #208
Bswope's Avatar
RJ
Ok guys here is a question.... would it be better to have one of the nozzles on the other side of the intake manifold? With both on one side it kinda seems that the water would be forced to stay on that side of the manifold so with one on the other side maybe the atomized water would be dispensed better between the cylinders. Im just thinking out loud here and remember im still learning fellas!
Old Aug 23, 2009 | 08:56 AM
  #209
Bswope's Avatar
Now that what Ive been looking for!! THANKS... I do have one question though....
How did you split the one line going directly into the manifold its self? I see the "Y" splitting the two that go to the intake plate but cant see how you did the one in the intake horn...
Old Aug 23, 2009 | 03:11 PM
  #210
doug60's Avatar
I took a few more pics
