Used smarty ?'s
Used smarty ?'s
I just bought a used smarty s-06. What is the first few things I should do before I install it on my truck? Or should i just plug it in and play? thanks
Is it safe to stack the smarty with the ez? whats the best setting for better mpg? Should i run even or odd numbers? whats the highest number i should go with w/out messing anything up with my mods below?
Sorry with all the questions just trying to learn!!
Yes, not only is it safe to run the EZ with the Smarty, but you will love it. You should run the even numbered programs if stacking with the EZ on an '03.
Personally from my experience your better off removing the EZ and just run the SMARTY programs. The REVO program can do pressure also. Also you want to run the odd # programs or manually set the timing in the REVO program.
MikeyB
MikeyB
Yea depending on how well your tranny is built, id remove the ez and install the smarty with the updated program. I got my smarty used a year ago and its never gave me a fuss. What part of La are you in?
I have the suncoast it has everything but billet output and intermedate! So what advantages is there with taking off the ez? And why run only on even or odds? Like i said before I am new to this! Im across the lake from new orleans in the covington area!
The EZ isn't a very smooth box. Tends to surge at highway speed, at least in my case. The SMARTY is so much smoother, actually it's better than stock.
Odd numbers on the SMARTY adds timing, which makes the engine more efficient, in power and economy, also lowers the EGTs.
MikeyB
MikeyB
stock03
34
04-21-2011 07:40 AM
hitcb1789
05-25-2010 09:10 AM
subspd
03-14-2007 09:21 PM
