Truck runs like cra* and throws codes
Old Mar 22, 2009 | 12:04 PM
BigJohnston's Avatar
Truck has lost alot of power and surges going down the highway. I truned off my X2 module from the Commander and uninstalled the Smarty and truck still ran bad. I physically removed the X2 and things definately improved. I reloaded the Smarty and my truck seemed alot more powerful than before when the X2 was installed, but as soon as I start the truck I get a P0234 and sometimes a P0243 code. How can I get an overboost code starting my truck I shouldn't have any boost and definately not enough to overboost. I am also seeing alot more smoke when starting truck and if I get on it and on the highway it doesn't seem to clear up like it used to. With the X2 hooked up I was showing sometimes really good rail pressure 24,500psi and sometimes it would show nothing or 3-4000psi which I know the truck could even run with much less go down the highway at 70mph. Now with the X2 removed my rail pressure is stable but seems low 16-17,000 going down the highway at 70mph and 21-22,000 when I get on it. Smarty is set to level 9 with level 3 for rail pressure. So how come I could see 24,500 with the X2 but truck ran like cra* and with it gone and rail pressure much lower truck is significantly more powerful? Thanks for any help, Tom J.
Old Mar 22, 2009 | 01:27 PM
JRD's Avatar
JRD
Maybe your Rail Pressure Relief valve is playing games with you at oddly the same time your modules are being swapped around. Wouldn't be the first time these type of things happen. Im sure Im wrong, but wouldn't hurt to look.
Old Mar 22, 2009 | 02:49 PM
justutt67's Avatar
You may have the wire rubbing problem that I have heard about. Some have had problems with a wire rubbing against your A/C line in the lower passenger side of your engine compartment. Once the wire rubs through its shielding it will touch the bare metal on your A/C line and cause your truck to throw codes and act possesed. It would be worth looking into!
Old Mar 22, 2009 | 02:51 PM
justutt67's Avatar
here is a link to the thread
https://www.dieseltruckresource.com/...ad.php?t=81936
Old Mar 22, 2009 | 04:33 PM
Thanks guys I will check it out............
Old Mar 22, 2009 | 08:55 PM
BigIron70's Avatar
Cummins Guru
Sounds like a wastegate solenoid, should be covered under warranty. Don't forget to remove all your performance stuff first or you will be red flag and warranty voided.
Old Mar 22, 2009 | 10:45 PM
sloride's Avatar
Have you read his sig? I don't think he's concerned much about a warranty
Old Mar 26, 2009 | 09:44 PM
BigIron70's Avatar
Cummins Guru
Since I work for Dodge I don't think so either.
Old Mar 27, 2009 | 06:08 AM
moorepower's Avatar
I had similar issues and ended up having to have the dealer reprogram my stock computer.
Chris Taylor
May 17, 2011 09:43 PM
tcr
Feb 12, 2008 02:56 PM
chw
Jul 16, 2007 10:39 AM
rstone
Nov 26, 2006 02:35 PM
razor6
Jan 22, 2006 10:35 PM
