truck throws unknown codes and dies in middle of road..help!
okay so im pulling out into traffic when all the sudden the truck just dies. i try to hurry and start it but it just turns over normally but wont start. i then push it to a parking lot and cycle the key for codes and try to crank it again. it cranks but now a check engine is showing so i plug the smarty in to check codes and it shows a p2149 and p2146 both are unknown along with a p1751 any thhoughts on what theses codes might be?
my mods are as follows:very big fluxes, helix 2 cam and springs, smarty beta 4.4, tst r49, ppe dual fuelers, twins and alot of others.
P2146 Generic Fuel Injector Group “A” Supply Voltage Circuit/Open
P2149 Generic Fuel Injector Group “B” Supply Voltage Circuit/Open
P1751 Chrysler Transmission Throttle Valve Position Sensor Minimum Range Performance
I would check the wiring harness on the TST, but with your mods there are a lot of possibilities.
BigJohnston
Mar 27, 2009 06:08 AM
02dodge2500ctd
13
Dec 11, 2008 07:29 AM
rstone
Nov 26, 2006 02:35 PM
razor6
Jan 22, 2006 10:35 PM
