Codes 0192 and 0193, truck runs like crap
Old Feb 12, 2008 | 07:19 AM
tcr's Avatar
tcr
I know what they mean, rail pressure sensor voltage too low and too high, but what's wrong? I took the Quadzilla out of the truck, all connections are correct. Could I have a bad rail sensor? Also my Quad rail gauge can't read the rail psi, it shows (----). Truck idles like crap, it is drivable but sounds terrible.
Old Feb 12, 2008 | 07:32 AM
vzdude's Avatar
DTR's 'Go to Guy'
Possibly a failed sensor, poor connection ( Someone has said they can go on backwards? ) or broken wire somewhere.....did you t-tap the wire?
Old Feb 12, 2008 | 07:37 AM
tcr's Avatar
tcr
No, I used the plugs and I'm positive it is connected correctly. This is an all of a sudden problem, Quad has been on for a long time w/ no issues. Gauge goes in and out working, then quits, works, quits.......truck runs real bad. I'm hoping it's a bad sensor.
Old Feb 12, 2008 | 02:56 PM
cwoodall's Avatar
Not when you see the price.................................
tcr
Feb 13, 2008 08:03 PM
reidsram
Apr 8, 2007 10:35 PM
reidsram
Apr 5, 2007 08:42 PM
reidsram
Apr 5, 2007 06:36 PM
