Tranny Gauge Question
Old Jun 18, 2008 | 10:39 AM
donnee's Avatar
Iv got a slight prob with my Isspro tranny gauge.
Ossasionally, it will work fine then go to zero
then work ok.
It acts like it loses power for some reason.
Any ideas as to what would cause this or how to fix it?
Possible faulty sender?
Thanks.
Old Jun 18, 2008 | 10:48 AM
paroxysym's Avatar
mine does the same, except it will read the actual temp of the tranny fluid- then fly over to the high side of the gauge and do this for a few minutes then settle back down to the correct temp. it is a problemw ith the ground wire... same with yours, check your ground wire. if you check/fix the ground and you find it still does it. call the company you got the gauges from and have them send you a new one, isspro covers it.
Old Jun 18, 2008 | 10:53 AM
donnee's Avatar
I was hoping it was something as simple as that.
If I remember right, the shop that installed the gauges, used the same ground lug for all the gauges.
All of the others work fine.
Thanks for the idea, Ill check it out.
Old Jun 18, 2008 | 11:03 AM
paroxysym's Avatar
yea i used the same for all 3 and my tranny gauge is the only one that acts up... may need its own ground?
the.hogman
Mar 9, 2011 06:13 PM
Black Dog
Dec 3, 2009 08:18 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
apc
Apr 8, 2003 05:51 PM
