TNT cruising speed egts!!!
Old May 19, 2008 | 08:14 AM
Dwitt0187's Avatar
i drove my truck up the interstate this past weekend with these settings
tq=3
tm=0
rp=2
sw=5
my egts where at 800* - 900* at 75mph is this normal with the mods in my sig
what kinda of egts is everyone else seeing driving down the interstate and at what speed
Old May 19, 2008 | 08:18 AM
jrussell's Avatar
That's normal for an aftermarket turbo. The larger the turbo, the higher the cruising EGT's will be.
Old May 19, 2008 | 08:22 AM
Dwitt0187's Avatar
is that too hot where it can cause problems??
Old May 19, 2008 | 08:35 AM
jrussell's Avatar
No, your fine.
Old May 19, 2008 | 08:45 AM
Dwitt0187's Avatar
cool thanx for the help just wanted to make sure i wasn't going to kill something
Old May 19, 2008 | 08:57 AM
MikeyB's Avatar
Your fine if EGTs doesn't exceed 1250 degrees during WOT with the '03-04 models.
MikeyB
Old May 19, 2008 | 09:31 AM
Gary Emerald's Avatar
buddy of mine has an early '04 that's seen 1600-1800* too many times to count. He finally dropped a valve seat at ~150k
Old May 19, 2008 | 09:32 AM
jlibert's Avatar
I'm seeing 800-900 when it's 100+ outside, and 750-800 when it's cooler outside.
Old May 19, 2008 | 09:46 AM
tcr's Avatar
tcr
Yeah, me too!
Old May 19, 2008 | 10:16 AM
jmccart's Avatar
My cruising yesterday (100+ degrees), on flat ground, was like 900. The bigger turbo makes it run a tad hotter light throttle.
Wow, I have never heard of a person going to 1800* before. 1600 is crazy high as it is.
Old May 19, 2008 | 10:24 AM
tristan21's Avatar
Yeah I bet the top of your pistons are a lil on tha soft side at 1800*
Old May 19, 2008 | 10:51 AM
goose2w1's Avatar
I did a 500 mile round trip from Southeren NM to Albq this weekend. TNT settings were #7-TQ3-TM3-RP2--Wastegate off. I set the cruise at 80-85 the entire trip and my EGT's were between 750ish and 850 the whole trip. Passing uphill I could get close to 1200. I even played with my X2 with fuel only tune and that didn't seem to effect EGT's much (maybe 30 degrees while cruising) but it sure did shot up RP. With the Quad on 3 I would cruise on flat roads at around 20,500 PSI and would easily hit 25,500 going up hills or passing. I turned it down to 2 and never saw above 23,00 PSI. Seemed to get a litle extra MPG too with the X2 on 2.
Old May 19, 2008 | 11:29 AM
Dwitt0187's Avatar
yeah i have hit that 1800* mark before im lucky i havent dropped a valve seat
phantom 309
25
Apr 8, 2009 10:51 AM
AKDSLDOG
May 26, 2005 09:37 PM
muddybeast
May 17, 2005 05:16 PM
ocliffie
Apr 25, 2005 11:52 AM
out_drsman
Jun 1, 2004 09:11 PM
