Normal cruising egts?
Old Apr 5, 2009 | 02:46 PM
phantom 309's Avatar
What are yalls normal egts when going around 70mph?
Old Apr 5, 2009 | 02:51 PM
DNRCustoms's Avatar
when towing how much... Big range there.. towing 10k 1k-1100 and 17-19lbs of boost
Old Apr 5, 2009 | 03:00 PM
what about when not towing?
Old Apr 5, 2009 | 03:02 PM
DNRCustoms's Avatar
at 70mph, with my tires and flares draggin me down 700 egt 7lbs boost..
Old Apr 5, 2009 | 03:33 PM
weird... mine are around 800
Old Apr 5, 2009 | 03:47 PM
nasty01cummims's Avatar
bout 650 and 5 lbs of boost
Old Apr 5, 2009 | 06:47 PM
DENVERDODGE04's Avatar
750 6-7#'s of boost
Old Apr 5, 2009 | 06:53 PM
cincydiesel's Avatar
600-650 with about 6 lbs on #5 set on the Edge
Old Apr 5, 2009 | 07:43 PM
jaredb900rr's Avatar
Mine are bout 700 at 70mph bout 5psi of boost.
Old Apr 5, 2009 | 08:19 PM
Townsend600's Avatar
700 bout 8psi of boost. at 70mph
750-800 10-13psi of boost at 80mph.
Thats with smarty tnt on sw 7 timing on 2 rp on lvl2 and wastegate off lvl4tq
Old Apr 5, 2009 | 08:36 PM
Rpainter's Avatar
70 mph 700 egt and 3-5 psi of boost
Old Apr 5, 2009 | 09:49 PM
dodgecowboy04.5's Avatar
Unless my Snow water and meth controller is wrong, i read between 500-600 flat cruising @ 3-4 psi. Going up hill depending on the grade 800-900 @ 10-20 psi with the smarty set on sw7.
Old Apr 5, 2009 | 10:44 PM
Well then what is the deal with mine reading on an average of about 750
Old Apr 6, 2009 | 07:01 AM
MikeyB's Avatar
Where is your probe mounted?
Also could be the accuracy of the probe.
MikeyB
Old Apr 6, 2009 | 04:16 PM
Could be wrong but isn't the Dr.P Stg. III a pressure box? Pressure = heat
