Tire Insanity - What to believe?
Old Aug 31, 2006 | 03:43 PM
  #46
MR. GADGET's Avatar
Originally Posted by XLR8R
You're too kind... I'd say you need some pretty tall boots to wade through sometimes!
Yep would say so!!!!!!!!!
Old Aug 31, 2006 | 03:59 PM
  #47
Kemble's Avatar
My load range D tires are comparable in load rating to alot of the Factory installed load range E tires. So just because they say D on the side, it is ok for someone to sue me for an accident?
I don't think so!
Old Aug 31, 2006 | 04:01 PM
  #48
ShawnQ's Avatar
I run D rated and they ride better then my previous 'E' rated stockers.
For what it's worth, if you get sued for running 'D' rated tires - turn around and sue the tire store/company that installed them
That's the American Way
Old Aug 31, 2006 | 04:03 PM
  #49
4x4dually's Avatar
O my God. Is this thread still alive? D's, E's, D's, E's, does anyone like C's?
Old Aug 31, 2006 | 05:10 PM
  #50
MikeyB's Avatar
C's are for gassers.....
MikeyB
Old Aug 31, 2006 | 05:41 PM
  #51
pet05's Avatar
Speaking of "road safe" tires. Just take a look while walking thru a parking lot one day. Look at the tires of the parked cars. You might be scared to drive home. The condition of some of the tires on those vehicles rolling down the roads will make you cringe.
So, all-in-all, I would not worry about a properly inflated, properly treaded, LOAD D range tire on your Ram.
Hey, if you get into a serious accident, have your insurance inspector pull the tires offthe offending vehicle, take pictures. Don't stop there. Take pictures of the pads, rotors and calipers of that vehicle. I bet you that the rotors are out of specs and the pads are worn and the calipers are not working properly. Most people do NOT inspect their brakes. Not to mention, that 5 year old car with 70,000 miles, I bet it still has the original brake fluid sitting in the lines. Brake fluid with that many miles on it is NOT working like it should be.
Don't sweat the D vs. E because their are A LOT more things to be concerned about.
Old Aug 31, 2006 | 10:40 PM
  #52
bbhzx12's Avatar
Sorry if I'm too late, I only read the first post.
Pro Comp Xtreme A/T's are great for traction, treadwear, and are E load range.
Old Sep 1, 2006 | 06:45 PM
  #53
oktire's Avatar
I also run a tire shop with in a few years every tire will be rated on a load index it is already marked on your tire's there will be 285/70r17 121/118q that will tell you the weight srws and drw and the q is the speed there will be no more load range d or e everything from car,semi and farm tires
Old Sep 1, 2006 | 08:29 PM
  #54
pet05's Avatar
That is good to hear that tire manufacturers will get rid of the LOAD D and E. As you can see, the whole issue causes confusion and strife. It always takes them years to catch up to the times.
A simple LOAD rating of how many LBS per tire is much simpler.
Old Sep 2, 2006 | 02:11 PM
  #55
HOHN's Avatar
Originally Posted by dodgezilla04
i just put on Toyo open country mud terrains 295/70/17 that are E rated. they go for $300/tire but are E range. check the gallery
Cool tires! The wheels are given me a gringo drug dealer vibe, but I dig the rubber parts
Old Sep 3, 2006 | 07:23 PM
  #56
wcbcruzer's Avatar
Could it be that an E rated tire is designed to operate continuously at max load and pressure when a D rated tire isn't? I don't know, it's just a guess. Maybe there's more to the engineering of the tire than we common folks know about.
Old Sep 8, 2006 | 12:25 AM
  #57
doznfire's Avatar
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHH My eyes are KILLING ME
Old Sep 8, 2006 | 12:30 AM
  #58
XLR8R's Avatar
!!!LMAO!!!
Tuckerdee
Jul 26, 2006 04:26 PM
Jack Thorpe
Dec 17, 2003 05:47 AM
BIG&BAD
Sep 14, 2003 05:05 PM
cfm3110
Mar 20, 2003 07:57 PM
scottrod
Jan 24, 2003 08:28 AM
