Tire Insanity - What to believe?
Originally Posted by MR. GADGET
I will not attack you, but you have no clue what tire I was talking about did you?
So You are saying that BFG tires are cheep and junk?? Man I just looked you run "cheapo d-rate " ( your word) BFG?
OEM Michelin Junk to?
OEM Goodyear Junk to?
OEM BFG Junk to?
Love to hear what you think is good?
Please add to it don't just bash people...
BTW my stock junk Michelin tires have 53+ k on them and I was loaded gross at 20K for the last load. They work for me.
SO you know a lot about tires?
Dad and Gramps worked for more then 40+ years for Goodyear Tire and Rubber
Just going off what people say that build tires and worked for years doing.
OEM BFG Junk to?
Any tire that fell apart as you say is cheapo junk by definition.
Did you ever see me write that BFG were cheap junk? The BFGs I run on both of my Rams are pricey, but worth it to prevent accidents/downtime.
OEM Michelin -
OEM Goodyear -
OEM Firestone -
OEM BFG - ??? always aftermarket for me
Have you read the posts?
I've already stated what I think is good - BFG AT KO (pick your size)... have not been able to overheat or blowout one in over 250K miles on two heavy service trucks (10K # 2500s). Is there better? Could be - and if I discover it, I'll buy it
Correcting misleading information is not "bashing".
I'm glad your Michelins have served you so well; they wear like iron but don't have the grip that I require. The e-rated OEM Goodyears overheated the sidewalls and exploded on the interstate...
Yes, I know more about tires than Joe 6-pack
I can see you do too, since you learned enough from Dad & Gramps to run Michelins.
Originally Posted by cquestad
I was saying that the OEM tire is not as capable as my aftermarket tire in every aspect. No disrespect to the manufacturer (or there workers) intended...
Goodyear/BFG/Michellen etc all make some great tires...and some not so great tires.
For example...IMHO...Rugged Trail...not so good. AT or MT great!
Only an opinion.
Only an opinion.
That was not for you..
But I go along with you there are better tires out there and I would like to run some of the bigger sizes along with others that float 100% better in sand and junk but, Out of all the tires I have had big and small I like the ones I have best FOR WHAT I USE the truck for best, Yes if I go play at the beach then I drive the Blazer or take a Jeep to play in the sand. This truck just will not cut it for a tow rig / off road rig it is one or the other for me.
Yep the Rugged trails are not the best, I told them to get anything but them when I ordered the truck.
Jon
Originally Posted by XLR8R
My, we're sensitive today...
That's right - in the real world, you get what you pay for, so it's no surprise a cheapo d-rate will be even worse than the cheapo factory e-rates.:
Did you ever see me write that BFG were cheap junk? The BFGs I run on both of my Rams are pricey, but worth it to prevent accidents/downtime.:
OEM Michelin -
OEM Goodyear -
OEM Firestone -
OEM Goodyear -
OEM Firestone -
:Does that mean the tires I have run are better? No just means I have had good luck with the tires that I have picked like you. ...
The load and weight are two different things from what I read.
And yes things have changed over the years.
I'm glad your Michelins have served you so well; they wear like iron but don't have the grip that I require. The e-rated OEM Goodyears overheated the sidewalls and exploded on the interstate...:
"run Michelins"
Jon
this post is hilarious
but NOW I am so confused I feel like this
I just bought some coopers that are D rated from Les Schwab and they said they are more than fine to run on my 3500. I thought I needed E's too when I went in to buy some new shoes and they told me otherwise.
this thread is drivinf me to drink
except I am not smiling
.but NOW I am so confused I feel like this
It would be a lot easier if when the tire junk is being posted we say what we want. Like What would be the best towing tire, or what is the best snow tire for towing, or whats the best mud tire if you never tow.
For what I do mine does fine but If I was in deep snow it is not the one or for sand on the beach it is not the one but works real good for me on the road and gravel/dirt roads.
Dont think that there is one tire that would rate best in everthing.
Pick 5 places and all 5 will tell you what it takes to sell tires.
NTB told me that P265/75-17 are the same as what I have now. BULL
Sears told me one of the P 265 just like what I got and after I laugh my a@@ off and said Bull and ask for someone that knows something about tires the guy told me that it would take a day or two to get the tires I needed and they know if they told me that, It would cost a sale.........
I tell you this because I did it for fun just like asking at auto zone for everthing I need for a tune up and that start looking plugs for me.
Wow, sensitive posting with a lot of well thought out posts and opinions. And then some others that aren't so much. It's like a great big think tank!!
I wanted E-rated tires to help with the sidewall flex on my 37" tires. I know nothing, but common sense tells me that a larger sidewall requires a stronger sidewall. But I ran 315 BFG's on my 2000 CTD, and they worked great. Who's to say? Not I, and we probably won't get an honest answer from the tire companies either. So all we have is each other....
I love you guys... sniff sniff.
It's your decision.
I suffered a blowout with 285-75-16 Bridgestone A/T's two years ago. $3300.00 damage to truck in maybe 15 seconds. Complete tread separation. Two other tires self-destructed here in San Diego and Baja. In defense of Bridgestone,they were "D" rated. Weight rating was sufficient but something went wrong. It's called insufficient load rating. My camper is on 24/7. I feel I'm atypical from the average camper hauler and tomorrow I finally have "E" rated Toyo's being installed. When I remove the camper I feel my present tires(same size,"D" rated BFG K/O's) are plenty strong. They are a vast improvement over the Bridgestone's excluding constant balancing. Three ply sidewalls make a difference. "E" rated BFG's of the same size are not an option. I'm looking forward to a round tire again.
If anyone cares, I own a Tire store and we sell all different brands of tires. On my truck, I run D load tires. They are rated for a higher weight carrying capacity, at 65psi, then the stock tires are at 80 psi. IMO, for the majority of poeple that don't tow really heavy on a regular basis, the D loads are fine. Mine are 295 Nittos and they ride and handle better than the stock BFG's did. I may only get 40k out of them though, so I may try something different next set.
Monday morning I had a customer in for a flat tire, he had an 05 3500LB manual 4x4 RAm with 150,000 miles on it
He said that he got 150k out of his original Michelins, so he just got another set of the same thing. I didn't see his original tires but I did see that he had brand new Michelins on the truck now. Even if they were the second set with 75k on them, I'd be impressed.
I'd prefer to run Michelins or Bridgestone, but neither make decent sizes.
You just can't live your life, worried about who's gonna sue you all the time.
Try to pretend that this is still a free country, not a lawsuit happy, over governed one.
He said that he got 150k out of his original Michelins, so he just got another set of the same thing. I didn't see his original tires but I did see that he had brand new Michelins on the truck now. Even if they were the second set with 75k on them, I'd be impressed.I'd prefer to run Michelins or Bridgestone, but neither make decent sizes.
You sir, have an excellent attitude!
Well, not really.
There sure is A LOT of different views on this topic. But I spent hours reading the old posts and from that I made up my mind already.
These forums can and have been a great source of information BUT they can also cause confusion. I wonder how many people make-up stories or exaggerate. I had the same thing happen on the Corvette forum when I owned my C5.
All-in-all, I love the forum
as it helped and continues to help me make informed decisions. One just has to filter thru some stuff to get to that.
I was on an F-Body (Camaro/Trans Am) site before here and I definitely hear you there. Everybody just has their own opinion and you have to decide whos opinion you value more. I've been doing that here for several years....
