Smarty timing !
Smarty timing !
Just curious if anyone knew about how many degrees the timing is advanced in the different levels with revo.The reason is cause no matter what level I set it on , it smokes,keep in mind that I tow alot.I don't mind the smoke so much except it covers the trailer on the curb side.
I didn't know if the timing is less than 4-6 degrees on tm 3.The r-49 can advance as little as 3 degrees as most of you know and the Rok-teck is about the same.Just want to get rid of that smoke, but cool egt's some and help with mpg
You're talking about sw 3 , tm 2 right? That has even more timing than tm 3.I've tried all timing levels and it still smokes even when cruising.I like the egt's but not the smoke.
AndyD
06-08-2010 08:25 PM
Honkylips
10-15-2007 07:07 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
