Cutting 45* an angle for stacks help needed
Old Jun 26, 2009 | 07:46 PM
dodge em's Avatar
I have a 7in peice of pipe and nothing big enough to go stright through, how do i get a templet or draw a line for a 45* angle?
edit:
yahoo yeilded no results but google did, put pipe in a bucket of water at the angle im looking for? I will give it a try but open to any others
Old Jun 26, 2009 | 08:55 PM
Pooter's Avatar
Best bet is a sharpie, mark 4 spots all around, basically cutting it in 1/4s, then more or less connect the dots and make your cut with a cutoff wheel/radiac, then clean it up with a grinder to make it all even/straight...
Do your bottom mark for the low side of the cut a certain distance(not sure what it would be for that angle, but at least you can eyeball it and measure and go from there)
Old Jun 26, 2009 | 09:25 PM
Sniper05's Avatar
See if one of your buddies has a 10" chop saw and they usaully have a setting for a 45* angle, i have done a couple like that and it works good, then clean it up with a grinder, works good!
Old Jun 26, 2009 | 10:20 PM
TORQUE BEAST's Avatar
wrap it in duck tape before you cut it and the chrome wont chip off. Find a chop saw or band saw and set it to 45 deg. and cut away.
Old Jun 26, 2009 | 10:23 PM
koreone's Avatar
cheap
Machine shopwould cost pennies
Old Jun 26, 2009 | 10:33 PM
DENVERDODGE04's Avatar
cut a 7" hole through a piece of cardboard slide it through the pipe then get a combo square or speed sqaure or anything that tells you a 45 degree, set the card board at 45 then mark the pipe using the cardboard as a trace. You might have to cut the card board a little at a time until it fits nicely at a 45 because the hole will end up being bigger the 7" to work right.
Old Jun 26, 2009 | 10:50 PM
rip 112's Avatar
Bandsaw would do the trick.
Old Jun 27, 2009 | 07:47 AM
johnnyboy_10138's Avatar
if it is a 7 inch diameter pipe, then put one dot on the pipe and then another one 7 inches up and 180 degrees opposite.
Old Jun 28, 2009 | 01:08 AM
dodge em's Avatar
I have a chop saw but when you angle it that steep it wont cut down all the way, but i got it, a guy was looking at a desk i have for sale and happened to have a band saw, got me cut and i told him to just take the desk. But thanks i will need to know becaus now a buddy wants his done...
Thanks again
Old Jun 28, 2009 | 11:57 AM
You could box it with wood and let the blade cut through the wood and use that as a guide, it should hold the blade at the angle you want.
LYNCHMOB
Nov 1, 2007 01:58 PM
Muddin_dude06
Dec 20, 2006 04:29 PM
CSAGrey1
18
Sep 16, 2006 07:46 AM
ppsi
16
Jan 5, 2004 05:42 PM
dsljunkie
30
Oct 16, 2003 06:16 AM
