Need Help...D60 caster angle?
Old Nov 1, 2007 | 09:25 AM
LYNCHMOB's Avatar
Can anyone tell me what the front D60 caster angle out of a '98 dodge should be? I've heard rumors that it should be 1.5-2 degree's, but I need to make sure. Can anyone help?
Thanks,
Ryan
Old Nov 1, 2007 | 01:28 PM
high bid's Avatar
Depends on what you have. stock or lifted? I believe that is correct for stock, lifted could be 2-3 degrees. I originally set mine @ the 2-3deg mark but then went and had it aligned so I'm not exactly sure what the setting is now.
Old Nov 1, 2007 | 01:58 PM
LYNCHMOB's Avatar
Yes, it will be lifted probably 6 inches, so should I shoot for 3 degrees? Is there a formula to figure out exactly what I need? Thanks for your help!
Ryan
Tobin
Jun 7, 2009 05:24 PM
Tommy93w350
Jan 4, 2008 10:33 AM
LYNCHMOB
Oct 22, 2007 02:44 PM
030303
May 28, 2004 11:19 PM
