Caster Angle on Leveled Trucks
After I installed my level kit, all I did was re-align the steering wheel to the center location, but never touched any other adjustments.
The truck does seem like it wanders a tad bit on the road, not too bad but enough that I was thinking about adding some positive caster to it.
Anyone else just thrown some more caster in it with good results, or am I way off here?
Tobin
Tobin
The caster is off when you levelled it and the axle is off center also if you did not adjust for it.
While it may not cause you problems, best results are get it centered and caster at or above factory.
ShawnQ
03-05-2011 10:04 AM
97CTD
02-24-2003 05:00 PM
