confused
Old Oct 30, 2007 | 06:09 PM
southerman's Avatar
confused
can anyone tell what the metal canister below the turbo is? it has trans. lines hooked to it never noticed one on the 1st generation dodges. thanks
Old Oct 30, 2007 | 06:14 PM
P.J's Avatar
P.J
Wastegate actuator?
Old Oct 30, 2007 | 06:37 PM
OlBlue's Avatar
Second Gen? It should be the transmission cooler for an automatic tranny.
Old Oct 30, 2007 | 07:10 PM
P.J's Avatar
P.J
Huh, mine on my 2001 Was up against the radiator.
Old Oct 30, 2007 | 08:10 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Heat Exchanger for the Auto Trans.
Old Oct 31, 2007 | 01:28 AM
SMOKNISB's Avatar
The tranny cooler is in front of the radiator. That is the Tranny heat exchanger that is below the turbo.
Old Oct 31, 2007 | 11:02 PM
JSPulliam21's Avatar
Exactly!!!
Old Nov 1, 2007 | 11:13 AM
JonnyThrottle's Avatar
i will explain this to you cause no did already...
Your auto tranny has 2 (two) coolers for it. one is an oil-oil cooler (under the turbo, against the motor), the other is an air-oil cooler (the one in your grille).
follow the tubes from the driver's side of your tranny and you will see where they go
Old Nov 1, 2007 | 11:37 AM
jrs_dodge_diesel's Avatar
Give that man a cigar !
Just like he said, there is a radiator style cooler up in front of the intercooler, and the heat exchanger "barrel" under the turbo. That one uses engine coolant to assist in cooling the tranny fluid.
Old Nov 1, 2007 | 04:20 PM
SMOKNISB's Avatar
I don't think I would call it an oil-oil cooler. Maybe a liquid-liquid cooler. It has coolant running through a set of fins inside, and the tranny fluid flows through the fins.
Old Nov 1, 2007 | 04:28 PM
Shovelhead's Avatar
That's why it's called a Heat Exchanger.
Old Nov 1, 2007 | 04:29 PM
Shovelhead's Avatar
And the original question was......
Not "What does it do"?
James2
Aug 1, 2003 09:05 AM
wheels
Jun 7, 2003 07:52 AM
w4xtc
Apr 30, 2003 01:03 PM
Rigg4x4
Apr 10, 2003 07:17 PM
The Boss Hog
Dec 20, 2002 05:03 PM
