cutting stacks
Old Sep 7, 2006 | 11:28 PM
CSAGrey1's Avatar
cutting stacks
Has anyone tried cutting chrome stacks? Can it be done without chipping and discoloring the tips? Reason I ask is because I found a set of 6" turn outs x 60" reduced to 5" OD for $145 or the same ones 40" for $75. I prefer the look of the miter cuts myself and was hoping to get these and miter the tops. Anyone done this with good results?
Old Sep 8, 2006 | 06:09 AM
fiveology's Avatar
I cut my 48 inchers down, but I cut the bottom not the top. I used a cut-off wheel in an air die grinder. It did not damage the chrome, but you would need a very steady hand to make a mitre cut with a die grinder.
Old Sep 8, 2006 | 12:14 PM
CSAGrey1's Avatar
I don't intend to use a die grinder. If the local exhaust shop won't sut them with the miter saw I will take it to Machine Services and have them do it with the water jet.
Old Sep 8, 2006 | 12:20 PM
BigBlue's Avatar
I'd wrap where your cutting it with a couple layers of masking tape to make sure you don't chip the chrome or scratch anywhere around it.
Old Sep 8, 2006 | 12:28 PM
signature600's Avatar
That's how I do it
Chris
Old Sep 8, 2006 | 01:11 PM
88bird's Avatar
i would think the waterjet would peel the chrome off...... i'd just tape them the way you want it and use an ancle grinder with a cutoff wheel.... take it slow and steady..... once you drive them 10-20 miles depending on your fueling situation you won't be able to notice that they've been cut....
Old Sep 8, 2006 | 02:07 PM
matthew05's Avatar
I just put my 5" stack on last monday and we just used a chop saw to cut the turnout to a miter. Didnt chip the chrome just deburr it good, then mask off all but about 1/4" of the top of the miter cut then use some good temp. silver paint, you wont never notice cause the first 1/2 inch of the stack will be covered with soot anyways.
Oh and I used a $15 stack take off from a local truck chrome shop as my stack, the way I see it is with such a small investment on the main stack you can always cut it off and add new(used) big rig take offs again.
my .02
m rector
Old Sep 8, 2006 | 02:36 PM
CSAGrey1's Avatar
How tall do they need to be?? Is 36" long enough?
Old Sep 8, 2006 | 07:10 PM
88bird's Avatar
ya mine are 36" and they look good to me.....look in my gallery....
EDIT didn't realize galleries were down..... here is a pic with 36" 5" mitres....
they look too tall in that pic but when you get at different angles it looks perfect to me....
Old Sep 8, 2006 | 08:22 PM
Topper's Avatar
If you have a local Machine shop ask them to cut them in a low speed band saw. I cut them all the time with no trouble. We also have a FLOW dynamic waterjet and a waterjet is about the last machine you would want to use.
Good luck,
Topper
Old Sep 8, 2006 | 08:30 PM
Crimedog's Avatar
Yeah, find someone with a big band saw, one of the ones that goes horizontally on the floor. That's how I did mine. I wanted a little more angle to the mitre.
Old Sep 8, 2006 | 09:04 PM
doodah's Avatar
hell, I freehanded my set!lol, looks really great, check my pix!, the other sets I have done, we just used a chopsaw. heck, the soot is gonna cover up anything on the top of the stack anyhow!
Old Sep 10, 2006 | 06:47 PM
CSAGrey1's Avatar
Well I the ones I would up getting are 60" straight. I think I am going to cut them about 4-6 inches above the cab and use flappers for the rest of the year and until spring. If I decide I don't like the flappers I will miter them in the spring.
Old Sep 10, 2006 | 07:20 PM
Sea Bass's Avatar
I think Doodah's are a perfect height for my taste. The tip is just hair about the cab. It looks a little more subtle but certainly know they're there.
Old Sep 10, 2006 | 07:29 PM
CSAGrey1's Avatar
SeaBass,
Did you get my message?
Sorry boss, I have been having problems with the NW Bombers site all weekend. I couldn't get into my PM's until today to retrieve your number!!
