#2 only |
06-27-2009 10:00 PM |
Smarty timing !
Just curious if anyone knew about how many degrees the timing is advanced in the different levels with revo.The reason is cause no matter what level I set it on , it smokes,keep in mind that I tow alot.I don't mind the smoke so much except it covers the trailer on the curb side[nonono].
I didn't know if the timing is less than 4-6 degrees on tm 3.The r-49 can advance as little as 3 degrees as most of you know and the Rok-teck is about the same.Just want to get rid of that smoke, but cool egt's some and help with mpg:cool:
