Smarty And Nv5600 Question
Old Mar 19, 2007 | 01:31 PM
OLD94's Avatar
How well does the Smarty work with the NV5600? what software is safe for the stock clutch?
How does it perform in each gear?
Thanks,
Joe
Old Mar 19, 2007 | 01:33 PM
BigBlue's Avatar
I wouldn't go much above level 4 or 5 with a stock clutch and even then it depends on how nice you are to it. If your heavy footed and slip the clutch and do lots of high rpm launches then I'd say level 2 or 3 but if your nice and easy on it then it should hold 4 or 5. Should being the key word.
Old Mar 19, 2007 | 01:37 PM
ramtd02's Avatar
yep, level 5 is max SAFE on a stock clutch, if you have a clutch in really good shape, you might handle 7 for awhile, but trust me.....one hard run on 7 and your clutch will let you know it is upset!!
Old Mar 19, 2007 | 01:47 PM
MikeyB's Avatar
No problems running on level 5 with the stock clutch.
MikeyB
Old Mar 19, 2007 | 02:45 PM
dodgezilla04's Avatar
5 on the stocker, as for perform in each gear? you are going to be hitting the redline so fast now that it is almost a waste to punch it in 2nd or 3rd. at least that's my problem. not that it is a real problem.
Old Mar 19, 2007 | 10:42 PM
drodgers's Avatar
x2, exactly.
Old Mar 20, 2007 | 07:07 AM
MikeyB's Avatar
Ditto....
But it really shines in 4th, 5th and 6th gear!
BTW, be careful on wet roads.
MikeyB
Old Mar 20, 2007 | 12:25 PM
ramtd02's Avatar
Originally Posted by MikeyB
Ditto....
MikeyB
AGREED...wet road in 6th gear @ 2000rpm and wot equals 7000+ pounds of tail wagging fun!!!
Old Mar 21, 2007 | 08:56 PM
nickleinonen's Avatar
yep... and just with mild#2 programed in..
Old Mar 21, 2007 | 11:27 PM
gus's 03's Avatar
i ran #9 for a while, i knew i had to be carefull between 1500-2k after that it would hold, but even in 5th, if you floored it in that range, it'd slip..
now, even on 5 she slips.. oh well... sbc will be in soon..
and to give you an idea how it runs... when it did hold....well it would run thru 6th gear faster on #5 than it runs thu 4th gear stock.
Old Mar 21, 2007 | 11:44 PM
tristan21's Avatar
gitcha a SBC dual disc and get the wild tq mgmt dl and set it on 9. I dont think you will be more happy with any other upgrade.
Old Mar 22, 2007 | 08:53 PM
gus's 03's Avatar
ive done the wild tq, but thought off idle resonse was to twitchy with as much trafic as i drive in.... some thing about that area below 2k rpm being like a light switch.. lol.. if i didnt drive every day in some of the worst trafic in the country id love it.. it was a blast driving it like that when there wasnt any trafic.
Old Mar 22, 2007 | 10:06 PM
Black04Ram's Avatar
Can you run the wild program with stock injectors, turbo?
Old Mar 22, 2007 | 11:07 PM
tristan21's Avatar
Ive heard its a no no but I would like to hear from bob or tim or somebody that would give the official axe. Even that may not change my settings though, I want a new turbo.
klawockvet
Oct 23, 2012 05:13 PM
quicksilvr
Aug 14, 2010 07:19 PM
35" 05'
Sep 12, 2006 06:00 PM
bnold
39
Jun 4, 2006 08:21 AM
getblown5.9
Aug 22, 2005 10:42 AM
