rokktech install...can't tell difference.
Installed a rokktech sensor. I can feel absolutely no difference in the truck.
Could some of you tell a difference when you installed yours? I'm wondering if it moved enough to make a difference. I followed the instructions and rotated it clockwise as far as possible while I tightened the bolt back down. It looked like the whole was only oversized about 1/32". I could have done that to the stock one in about 5 minutes.
Oh well, it's only money.
Anyway, should I have noticed a difference?
You should have felt a bit more bottom end power and you should get better mileage. I don't think the stock sensor is adjustable. Some of these trucks benefit greatly from certain mods while others see no gain.....
Without any performance boxes or chips you 'might' feel a difference with the Rokktech. My truck after the install I noticed the power surge that happens at 2k rpms moved down to 1500rpms. With the EZ on I don't notice it.
What you should see is a drop in EGTs of around 100 degrees or so.
MikeyB
MikeyB
I noticed quicker throttle responce, quicker spool up of the turbo. Now the truck has better bottom end, not huge difference but noticable. I haven't noticed any mileage gains, but then I drive it like I stole it. I didn't have any other mods on when I put the sensor on.
tyroneweaver
Jan 4, 2013 09:26 AM
Totallyrad
Jul 19, 2011 07:41 AM
jcarrillo
Jan 9, 2010 04:46 PM
Stainless
32
Feb 29, 2008 09:35 AM
