Rail pressure questions... Cruising and get out of the throttle, what does yours do?
Old Mar 13, 2008 | 01:09 PM
5.9Excursion's Avatar
I'm doing some troubleshooting and need to know how other trucks act...
If you are cruising down the road at highway speed and you let completely off the throttle, what does your rail pressure do? Drop, stay the same, go up?
Also, when you get back into the throttle what does it do? Go back up or drop first then go up?
Thanks for any help, I'm trying to determine if I have a problem or not.
Old Mar 13, 2008 | 05:22 PM
jlibert's Avatar
cruising at 70, pressure steady at 20k
let off and it immediately drops
get back in the throttle and it immediately shoots up to 23k and if I'm wot it will build to 24k sometimes 25k. 4.10 BA431 tune (similar to 4.4) Doesn't drop
Old Mar 13, 2008 | 05:23 PM
PEAKSTRYDE's Avatar
When I get out of the pedal quickly it goes up 1.5-3K from what I was running at. Then immeadiately drops ~10K until I get back into it again. Doesn't matter if I get in it hard or ease back up to a cruising speed it will always climb until it is not demanding any more fuel.
Hope this helps
Old Mar 13, 2008 | 07:33 PM
Ok, then I definately have an issue.
Cruising 70 or so, it is around 13-14k. If I let off the throttle, it will raise to 15k and stay there until I slow to less than 10 mph or until I get back into the throttle, in which case it will drop to somewhere around 3k (sometimes 2k) and then come back up to 13 or so. It causes a full second delay before the power is back or starts to come back.
Anyone know why? Sticky FCA?
Old Mar 13, 2008 | 08:02 PM
PEAKSTRYDE's Avatar
Any poss. of wrong voltage or computer issues????
How does this compare to your previous problem??
Sounds like a sticky FCA again......................................
Old Mar 13, 2008 | 08:57 PM
Previous issue was that the rail pressure was 14.5k max. Turned out the ECM needed a vehicle speed signal or it defuels. So I got that connected, and max rail pressure was then around 18.5k.
Bob W. sent me a recovery file and I reflashed the ECM to clean up any possible issues created when the dealer put my VIN # in for me. Then I loaded a different smarty software aftermarket turbo/stock injectors mod TM onto the ECM. It does run alittle better, max rail pressure is around 20k.
However the issue with the pressure drifting up after getting off the pedal, and then dropping first when I get back into the throttle has been there from day 1.
When I disconnect the rail pressure connector, rail pressure goes straight to 26,500 psi...
Old Mar 13, 2008 | 08:59 PM
elirandolph's Avatar
It sounds like your cruising pressure is right (10-13k). 20k at 70 sounds high to me and I even run a pressure box. But i think you definitely have a problem. Mine drops immediately.
Old Mar 13, 2008 | 09:48 PM
Don M's Avatar
DTR Advertiser
FCA is roached
Old Mar 13, 2008 | 11:02 PM
I guess that's next on the list then...
Old Dec 14, 2008 | 05:17 PM
sallyman1's Avatar
when i gun fuel pedal half way and then let off quickly it seems as though fuel/rpm stay for like 20 seconds. i have to use brake hard to slow truck down and rpms still stay high. just sometimes.is fca sticky? because i replaced it this past summer.
Old Dec 15, 2008 | 11:30 AM
rodriguez7's Avatar
Jlibert, is this 4.10 a custom tow tune? Or is it just one of the older tunes? Just curious cuz you say its similar to the 4.4 which was a beta tow tune. Sorry im not trying to hi jack this thread.
Bookshelf
13
Nov 13, 2008 05:06 PM
5.9Excursion
Mar 13, 2008 10:56 AM
1stTimeAround
Jul 6, 2006 03:24 PM
1stTimeAround
Jul 6, 2006 03:01 PM
erics76
15
Jul 14, 2005 09:46 PM
