Rail Pressure Guage Question
Old Dec 8, 2009 | 01:59 PM
Diesel87's Avatar
Rail Pressure Gauge Question
I am in the market for a rail pressure gauge. I have heard way too many bad things about Quadzilla so that is not an option. I am really wanting a reliable gauge. I don't think Autometer makes a RP gauge do they? I would really like to have a Autometer Cobalt RP gauge if they make them. I have Dipricol boost and pyro gauges, and they make a RP gauge, how reliable are they?
Old Dec 8, 2009 | 02:59 PM
AH64ID's Avatar
I liked my Pricol RP... Its that or ISSPRO.. only 2 choices other than Quad.
Old Dec 8, 2009 | 03:28 PM
rich's Avatar
i run a bully dog outlook and it has several guge choises in it including the rp. you dont have to have the program to use it
Old Dec 8, 2009 | 08:52 PM
Diesel87's Avatar
Anybody else running the dipricol RP gauge? If so how do you like it?
Old Dec 9, 2009 | 02:00 AM
6 Shaker's Avatar
I had a Dipricol gauge, but it never worked right. I have the Isspro now and like it a whole lot better.
Old Dec 9, 2009 | 09:32 AM
CD in NM's Avatar
I had a DiPricol RP gauge for 3 years, it worked perfectly, never had a problem with it.
When I decided to change my gauge locations from the a-pillar to a custom dash pod, I decided to install the ISSPRO EV2's, I now have their RP gauge, it works perfectly as well.
Either gauge will serve you well, just depends on which you like the appearance of. I don't think an other mfrs are offering a RP gauge but you could go to their websites and ask them. Sometimes a mfr will put a custom gauge together for you.
CD
Old Dec 9, 2009 | 09:39 AM
Diesel87's Avatar
What is different between the two gauges? The Dipricol and Isspro gauge look almost identical. What was the problem with your Dipricol gauge?
Old Dec 9, 2009 | 01:06 PM
qzilla's Avatar
Just FYI, the rail pressure gauges now are WAY different than the originals.
I don't think I have ever heard of any issues at all with the new ones, they are 110% rock solid! And you can add the FP sending unit to them and have a dual gauge.
Old Dec 9, 2009 | 01:20 PM
BigTXDually's Avatar
Ive been running a DiPricol gauge for nearly two years now. About a month ago I started having problems with it not reading correctly for a bit then it would start working again. When I called DiPricol they said that I had an "old model" gauge and that now the newer gauges have different wiring harnesses and parts to them and that there should not be anymore problems.
Ad removed
Old Dec 9, 2009 | 02:04 PM
cbrahs's Avatar
I was given a quad gauge and have not had a single issue. Don't have the FP side but the Rail psi side works like a champ. 5 months zero issues
Old Dec 9, 2009 | 03:05 PM
silverrhino's Avatar
I was going to buy a dipricol RP and FP gauge today, but the place I normally get my gauges from quit carrying the RP gauge.
So what's a good rep for dipricol gauges?
Old Dec 9, 2009 | 05:57 PM
I dont know what "Ad" was removed. If you are looking for another alternative to buying a rail pressure gauge from either Quad, DiPricol, or ISSPRO you can check out a gauge from a company called ProParts. Their gauges are some of the best I have ever seen. their website is propartsllc.com . Their rail pressure gauge for the Dodge CR should be available soon (around the 1st quarter of 2010 is what I have been told) .
Old Dec 9, 2009 | 10:41 PM
Fisherguy's Avatar
The new Quadzilla ones are trouble free I here.
5.9Excursion
Mar 13, 2008 10:56 AM
jgiachino
16
Jul 11, 2007 07:33 PM
trik396
Jun 14, 2007 05:41 PM
rich2500
Aug 22, 2006 09:47 PM
bigragu
Jan 24, 2006 11:16 AM
