Quadzilla Race @ Idle?
Old Dec 7, 2006 | 08:35 AM
tcr's Avatar
tcr
I've got the 4 position 140HP Race box and w/ positions 2-4 at idle I get a very inconsistant idle, very rough and the truck vibrates and shakes w/ the roughness. Is this normal? I have not had this w/ other pressure/timing boxes.
Old Dec 7, 2006 | 09:12 AM
welndmn's Avatar
Did you just buy this an install it?
Old Dec 7, 2006 | 10:07 AM
tcr's Avatar
tcr
Yes, It's been on for two weeks or so. Other than a rough idle it runs great! Blows the doors of my Banks set up, I'll have to admit.
Old Dec 7, 2006 | 10:11 AM
carcrz's Avatar
Mine does that too on occassion. Probably once every 2 weeks or so.
Old Dec 7, 2006 | 10:28 AM
tcr's Avatar
tcr
I'm talking about 100% of the time, we've had some serious weather changes in the last two weeks, and outdoor temp has no affect on it, 30*-75*. I also added the Smarty to the mix to see if more timing made it worse or better, w/ no changes. It's all in the Quad box from levels 2-4. On level 1 it's quiet/consistant as can be. I know there's supposed to be a engine tone/sound change as you adjust, that's not what I'm talking about. I'm talking about a rough inconsistant idle.
Old Dec 7, 2006 | 10:50 AM
ptgarcia's Avatar
My standard doesn't do that at all on any setting. Did you check your harness and make sure everything is plugged it completely?
Old Dec 7, 2006 | 11:13 AM
tcr's Avatar
tcr
I've checked and cleaned all connections, then did it again to be sure.
Old Dec 7, 2006 | 11:42 AM
dodgezilla04's Avatar
did you buy it new or used. there is a flash sequence that the leds go through when the key is turned on. look at the color sequence, check in your manual that they are the right color sequence for your model and year. then call quad with the module serial number and led color code. i usually talk to roarke, jeremy is great too.
Old Dec 7, 2006 | 12:12 PM
tcr's Avatar
tcr
Yes, all flashes are correct for my year/model. Everything works great, I'm just uneasy about the idling.
Thanks.
Old Dec 7, 2006 | 12:58 PM
Duallydog's Avatar
Is it something that occurs after a cold start up?
Old Dec 7, 2006 | 01:14 PM
did you give them a call?
817-306-2444
888-842-6572
Fax 817-306-2454
E-Mail:
General Information:
info@quadzillapower.com
Old Dec 7, 2006 | 01:31 PM
tcr's Avatar
tcr
No, it happens all the time, cold and warm. I guess I will call Quad, I just wanted to see if it was normal w/ other users.
Old Dec 8, 2006 | 12:55 PM
TJBUGGIE's Avatar
tcr I am in Astin as well, and run the race box on an 05, and I get a little shudder every now and then, but it is smooth the rest of the time.
QWKSLVRZ06
Nov 26, 2011 02:59 AM
BigBully
Mar 18, 2009 10:01 PM
BigJohnston
Feb 7, 2008 06:14 AM
LinearX
14
Jun 14, 2005 04:48 PM
RockRover
Mar 15, 2005 01:14 AM
