S472 w/race or S480 w/race cover that is the question
Old Mar 18, 2009 | 03:30 PM
BigBully's Avatar
I am doing a Low budget set of compounds with the stock 03 turbo for the high pressure and I am not sure whether I want an S472 With race cover or the S480 with race cover,
I have 90hp DDP Injectors, II Modded CP3, Fire Ringed head, And I will ad a second CP3 later on.
What is your suggestions? I need to figure this out asap. Thank you.
Old Mar 18, 2009 | 06:14 PM
04DEEZELRAM's Avatar
Since your going to run a stock turbo you should go with s s400....there is to big of a gap between the stock turbo and a s480, but im not sure with the s472
Old Mar 18, 2009 | 06:48 PM
blowin smoke 03's Avatar
Whats your HP goals???I'd say T-6 1.10 ar, 72 mm,but really no need for the 80 with a stock charger.
Old Mar 18, 2009 | 07:29 PM
AlanB's Avatar
Say you wanted to add a bigger high pressure turbo later would the 480 still be drivable with a stock charger?
Old Mar 18, 2009 | 07:53 PM
chrleb1's Avatar
I'd try to find a stock 04.5+ turbo. It will support the hp a little better. A 72mm will handle 650 easily.
Old Mar 18, 2009 | 09:16 PM
jaredb900rr's Avatar
There's good reading here, https://www.dieseltruckresource.com/...d.php?t=233890
Listen to what Idaho CTD (Nathan from MPI) has to say, he knows what he's talking about! I like the idea of porting the wastegate on the stocker.
Jared
Old Mar 18, 2009 | 10:01 PM
BigBully's Avatar
My goal is to stay anywhere from 650 to 750. Im pretty sure I will be happy in that neigborhood. I also think that the S472 will satisfy the 2.8 rule in my pulling class so maybe its best to go with that one if I decide to pull with that truck too.
torybarter
0
Jan 20, 2011 03:13 PM
homewrecker
Jul 11, 2008 02:54 PM
homewrecker
14
Jul 1, 2008 10:48 AM
mykal41
23
Jun 6, 2008 12:42 AM
nrussell
22
Apr 23, 2008 02:50 PM
