quad xzillarider race module
Old 09-03-2007, 03:46 PM
fitz1985's Avatar
dose any one have this.. i know alot of u have the quad XZT but i want something with a little more HP... dose it stack well with smarty tunner.. what all dose this chip do boost foolin, rail pressure stuff like.. im looking for some thing that stacks well with smarty.. i have a 05 5.9L totaly stock. AFE intake and 7 in stacks comeing... i was thinking of TST box also.. i would like a chip thats ajustable on the fly...any advice would help.. thanks
Old 09-03-2007, 03:57 PM
Rpainter's Avatar
I would not stack anything until you get gauges, fuel system, trans, and maybe a turbo.I am running the quad race module it does boost fooling timing pressure and duration I have mine stacked with a bullydog
Old 09-03-2007, 04:18 PM
fitz1985's Avatar
if the quad xzillarider race module and the smarty both play with the timeing wont that mess it up.. like to far advanced. or some thing like that. i new to all of this, so please like me know if i got it wrong...could some one explaine all this to me. and yes if your wondering i DO have gauges on the way and WILL be the 1st thing i install...
Old 09-03-2007, 04:45 PM
jncornett's Avatar
you can either have the timing removed from the quad (send it back or order it without timing) or just run the smarty on the even numbers. the even numbers do not add timing on smarty..
I hope this helps.
Old 09-03-2007, 05:51 PM
goose2w1's Avatar
I don't have a Smarty to stack it with, but the stack version of the Race is awesome. A ton of power, and you can feel it all over the RPM range. Right now I'm playing with settings, but currently with the Predator on extreme and the Race on 60 HP, watch out
Old 09-03-2007, 06:21 PM
2003Ram's Avatar
Quad stacks well with Smarty. Use even numbers on Smarty.
My experience and others have confirmed is that the 140 setting of the Quad Race adds NO additional power over the 100hp setting. So save yourself some $$$ and get only the 30-60-100 box if you want the Quadzilla brand.
Old 09-03-2007, 07:48 PM
goose2w1's Avatar
I have to disagree with this a bit. I don't have the seat of the pants experience with the 140 setting, but it definitly adds 2K to the rail pressure. It might be small at best, but 2K extra rail pressure has to mean something. Then again I have the stacker tune, so that might make it a bit different.
Old 09-03-2007, 09:09 PM
fitz1985's Avatar
if i stack both of these will it drail the fuel rail.. ok i know this is a dumb question but what is rail pressure.. and when u up the rail pressure what dose that do?? what happens if there is to much or not enuff? the quad race module raises rail pressure if im not correct.. do u want to keep it up or down? and what kind of fuel pump should i get like ATS,industrial injection. PPE... and one last question for now at least... what is a lift pump and what dose it do... if i dont ask ill never know... thanks alot guys..
Old 09-03-2007, 09:28 PM
shortbed rv's Avatar
Lift pump: transfer fuel from the tank to the injector pump. More rail pressure =more fuel, more power, more smoke: too much is bad for injectors.
Fitz, you need a plan. What do you want to accomplish, better towing, 1/4 mile time, dyno result etc. Get a budget,a plan and come on back and ask some question.
good luck
PS, please fill out your sig so we know more about your truck
Old 09-04-2007, 06:48 PM
fitz1985's Avatar
ok my plan is just to play.. i have my work truck that i drive to work.. then there is my play truck i dont want to much power just enuff to run with my buddys.. rat raceing around, every once and a while hookin up to a sled and drag raceing down the old country roads. ..this is like my weekend truck i try and keep the miles down.. i 21 years old i make a lot of money, i have a truck payment and a cell phone payment thats it, so i got a pretty good budget i make around 1,600 a week and its only gonna go up... so bring on the sugestions and advice on what yall think i shoud buy... i dont want to melt pistons or any thing like that... i just want something that halls *****. i DO expect to blow the trans up.. i all ready have a nother one lined up... i will probley put a south bend clutch in it... thanks guys, i have gottin so much info from this site....
Old 09-04-2007, 06:52 PM
ptgarcia's Avatar
..... i make around 1,600 a week and its only gonna go up... so bring on the sugestions and advice on what yall think i shoud buy...
Real estate.
Old 09-04-2007, 07:33 PM
DTR 1st Sergeant
soulezoo's Avatar
Originally Posted by ptgarcia
Real estate.
BEST ADVICE I'VE SEEN ON THIS FORUM YET!!!
Old 09-04-2007, 08:08 PM
fitz1985's Avatar
nope im an union operator.. local 150.
Old 09-04-2007, 10:13 PM
1. Gauges, you said on the way good!!
2. Trans upgrade: valve body,billet input and Torque converter.
3. fuel system upgrade a gdp 392 kit. The stock pump can not keep fuel to the injector pump when you add performance.
Now you are ready to improve performance.
4 Wait until you finish the above mods by then Qaud will have his improved box on the market.
Have fun and be careful
buickturbot
08-13-2007 10:24 PM
Hoss
01-08-2007 02:34 PM
DWG05
11-26-2006 12:29 PM
carcrz
10-31-2006 04:45 PM
coobie
04-20-2005 01:00 PM
Quick Reply: quad xzillarider race module
