Quad Boost Fooler
Quad Boost Fooler
I just got this and put it on my 04.5. Before I was making about 32 lbs of boost and highest egt's of about 1450.
With the fooler I was making about 38 lbs of boost and the highest egt's I saw were around 1150-1200.
All the tests were done while the predator was set on the 100 hp setting. I have returned the truck back to stock settings on the predator and am going to test to see what the egt's and boost are under those conditions on my way to and from work tonight(Darn swing shift)...
Now I just need to get some injectors, lift pump, turbo, tranny, etc....maybe by next spring I will be halfway happy.....
Oh, is there any to quieten down the infectors? Mine are so loud I started out thinking it was a valve ticking...
One thing I noticed when I ran it only pulling my toyhauler up the hills the truck didn't pull well at all. Actually notice egts a bit higher as well. I actually had to pull it off and stay stock. I feel that it like taking a great power set up and only useing a fraction of the hole. It does something but it works better when everything in line. It's like you inprove one thing but the rest needs to bumped up to match the first.
Just my 2cents.
Just my 2cents.
jmccart
Apr 5, 2011 06:13 PM
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rkelley
19
Jan 11, 2007 10:59 PM
Herrin811
Sep 22, 2006 11:38 AM
