predator
Ok guys bought a predator chip , stage 2 suppose to have the wires to run a cut off switch and the monitor got and it says stage 2 but no wires. wonder if I got a old model? any ideals it does have the model and serial#
I just got the stage 3 and it has an extra orange wire, for the trailer brake/monitor hook up that predator sells, as well as a smaller gauge yellow
wire, which is the on/off wire if you desire to hook up a switch.
I did however, try the stage 2 before the three, and the one i tried had the same wires as the three.
rmb93243 what are your exhaust temp on yours? is yours the 600 are the 555s I'm thinking about calling to see why mine did'nt have the other wires,also if you don't mind how much did your gauge setup cost you?
I guess it wouldsvae a lot of back & forth if I'd read you profile sorry
I have a "Predator" Stage II that I bought about 3 weeks ago. I bought it from a local dealer for Dr. Performance products.
I can post pics if you want later from home. The box is labeled Dr. Performance Stage II for 2004.5 Cummins 5.9L 325/600. The unit is also labeled the same way. Does not say "Predator" anywhere. The local salesperson said that is the way they will be labeled from now on.
The unit does have Fuel connector, MAP connector, the wires and instructions for ON/OFF switch and control module. I have not hooked up either of these options. I have gauges and the de-fuel control is the bottom of my shoe.
So far I am very pleased with the unit. Dropped my quarter mile time by 1.2 seconds.
abb
My exhaust temps with afe air intake. Stock exhaust hit 1440 during 1/4 runs. I can peg a little over 1400 with WOT from about any speed/rpm.
I am having Banks Monster exhaust put on today, and hope that will drop the EGTs a little.
abb
I got the Dipricol Gauge and single pillar mount from DPP and I think it was about $170.
TruckTuner
30
Aug 3, 2004 09:19 AM
coolslice
Jun 20, 2004 09:36 AM
Texas Crew'd
May 25, 2004 04:44 PM
Scubasteve
Dec 13, 2003 12:01 AM
