possible boost fitting places...boost bolt?
Old Apr 24, 2007 | 03:12 AM
moparmatt's Avatar
well i finally ordered some autometer phatom guages and i was wondering where do i mount the boost line on the block for a 24v i have done my dads 12v but he had and easy bolt on the left side of the block to remove in place of the new fittings...i have searched this topic and cant find what im looking for... what i was wondering is instead of ordering a boost bolt can i make one from some bolts and ntp fitting at a local parts store and i do not wnat to drill and tap my intake so if there is any other easy spots with good boost reading please give some advise thanks
Old Apr 24, 2007 | 03:59 AM
megafast's Avatar
I ordered a boost bolt, and highly recommend it if you are not wanting to drill and tap. Super easy way to go. I ordered mine from dieselmanor.
Old Apr 24, 2007 | 07:55 AM
deezulsmoke's Avatar
Like Megafast said, just get the boost bolt. I drilled and tapped mine, but the bolt is a lot easier and quicker to do, it is already drilled and tapped to accept the fitting for the boost gauge.
Old Apr 24, 2007 | 08:40 AM
jrussell's Avatar
Does the boost bolt only go in that one spot where Diesel Manor suggests?
http://www.dieselmanor.com/diy/CMS3-gauge/G3image5.htm
Or can you use it to replace a different intake bolt and still get a boost reading? The spot they suggest is way back there and really cramped up next to the injector bolt. I had to use a short piece of tubing to extend it out because my SPA boost gauge sensor was too big to fit in that spot.
Old Apr 24, 2007 | 09:11 AM
CG98x's Avatar
I'm almost positive you can use it on any of that inside row of bolts.
Old Apr 24, 2007 | 10:06 AM
RamWheelsBy4's Avatar
Yes you can use it on any of the bolts, that one just seems central and fairly easy to get to. It is the one I used. I doubt the readings would vary enough to see and would only be vary momentary.
Old Apr 24, 2007 | 10:42 AM
sdmark's Avatar
I have a stock manifold with that is already tapped and filled with the fitting. I will send it really cheap.
Old Apr 24, 2007 | 10:46 AM
jrussell's Avatar
Thanks for the info guys. I guess I should've asked that question before the install.
In hindsight I'm still glad I went through the trouble to install it there because it forced me to use that extension piece. The sensor is electronic and bolting it straight to the almighty Cummins probably isn't the best way to go.
Old Apr 24, 2007 | 09:59 PM
moparmatt's Avatar
alright thanks for the help guys i was also wondering if that boost bolt was just made from few little bolts that i could get at my parts store..dont really like bothering my parents to order me stuff as i have no visa, so i would just rather go and see if i can rig one together
Old Apr 25, 2007 | 02:13 PM
moparmatt's Avatar
has anyone just made there own boost bolt and if so what size of bolts and fittings did you use?
Tommy93w350
Nov 16, 2016 06:40 AM
Moobesor
Jul 15, 2008 03:07 PM
AAmeeting
Sep 13, 2005 09:35 PM
doomgaze
Mar 26, 2003 05:36 AM
