Common Places for Gooseneck Hitch Pop-Up Lock?
Old Mar 25, 2003 | 11:20 AM
doomgaze's Avatar
Alright. I have had my truck a year now and I've never had to use the gooseneck hitch. But I'd like to know that I am able to when I have to.<br><br>I've tried to pop the hitch up, but it's either rusted very badly down in there or it's locked. I'm voting on the second option. Because we've soaked it in WD40 and even used a pipe on a jack stand positioned on the ball from under the truck to try to push it out... well, we had the truck off the ground and that thing still didn't budge.<br><br>Unfortunately, this was one question I forgot to ask the guy when I purchased my truck! I thought it'd be a no brainer to pop up!<br><br>
Old Mar 25, 2003 | 11:25 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Common Places for Gooseneck Hitch Pop-Up Lock?
Check in the front of the left rear driver's side wheel well to see if there's a lever in there to release the ball.
Check here for more info.
http://www.turnoverball.com/turnover/
Old Mar 25, 2003 | 02:01 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
And by the way.....here's your sign. ;D :P
Old Mar 25, 2003 | 03:04 PM
TXBobcat's Avatar
spekaing of gooseneck hitches...... I am thinking about putting a hitch in my truck. I want to do it myself, but am not sure how hard it will be to get the bed raised on my truck. ???<br><br>It is a short box 1500 Dodge Ram. I plan to weld a piece of heavy channel across the frame, but I am pretty sure I will need to raise at least the rear of the bed to get this accomplished. How many bolts, and how many other parts will I need to remove to get the bed raised up to install the channel? All tips are appreciated. ;D
Old Mar 25, 2003 | 03:17 PM
shortfieldbreak's Avatar
I got a B&amp;W gooseneck hitch, and got it installed without moving the bed or anything. I did take out the spare to make it easier to get to though. It just bolted right in, and then had the guy at the trailer place tighten up the bolts I couldn't reach very well. You shouldn't have to weld anything (as far as I know)<br><br>-SFB
Old Mar 25, 2003 | 03:37 PM
TXBobcat's Avatar
[quote author=shortfieldbreak link=board=10;threadid=12723;start=0#120315 date=1048627020]<br>I got a B&amp;W gooseneck hitch, and got it installed without moving the bed or anything. <br>[/quote]<br><br>What did the B&amp;W hitch cost? Also, what type design is it?<br><br>I am trying to get out pretty cheap since I probably won't be keeping the truck a whole bunch longer. I figure I can get a piece of 6&quot; channel for $30 or so, and then all I will need is the ball. I already have a 6 pin plug, but will probably need a brake controller installed.
Old Mar 25, 2003 | 08:01 PM
doomgaze's Avatar
There is no lever inside of the wheel well, that's what puzzles me.
I've had several people look at it and no one can figure it out.
Old Mar 25, 2003 | 09:49 PM
PistolWhipt's Avatar
Does your lock lay flat on it's side just under the bed with a metal cover over it ?<br> <br>PISTOL
Old Mar 25, 2003 | 11:16 PM
Srigs's Avatar
TXBobcat,<br><br>I have installed my Putnum Popup Gooseneck hitch now on two Dodges on the 96 1500 and my CTD 97 2500. The 2500 was much easier and both were bolt up to existing holes in the frame. 5 holes in the bed 1 - 3&quot; and 4 - 5/8&quot; for the breakaway chains U bolt.
Old Mar 26, 2003 | 05:36 AM
MrBilly's Avatar
What brand of gooseneck hitch is it? Might call them.
gmcmhdriver
13
Sep 12, 2010 06:18 PM
matthopp
Jul 14, 2010 08:33 AM
tatkins85
Mar 16, 2008 01:32 PM
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
