Popping Noise in Steering
Old Mar 13, 2007 | 11:29 PM
david_4x4's Avatar
Question Popping Noise in Steering
Last week I installed my Lorenz leveling kit and Thuren trac bar. So far so good until tonight. Navigating the parking lot I noticed a popping in my steering that only occurs when going to full lock either way. I figure tomorrow morning I'll go through and re-tighten everything, but just looking under the truck tonight nothing "seemed" wrong.
Any ideas on what I should look for when under the truck?
Old Mar 13, 2007 | 11:59 PM
53 willys's Avatar
like you said go through and re-tighten everything back up hopefully that works...that would be my first place to start.
did something get put in backwards so that it comes in contact with the steering components??
just throwing out some ideas???
Old Mar 14, 2007 | 12:14 AM
973604x4's Avatar
it could be TONS of things. shocks, tie rods, blah, blah.
my popping issues turned out to be 2 bad tie rod ends. Only occured at low speed when turning, more common if hitting a pot hole or speed bump.
Old Mar 14, 2007 | 07:11 AM
Lsufan78's Avatar
tighten your track bar!!
Old Apr 18, 2007 | 10:14 AM
david_4x4's Avatar
I dont know what's up. Still popping. Everything is tight and aligned.
The power steering pump went out twice, thought maybe that may have been the cause. But no. I dont know what else the issue could be. I've had it on jacks pretty much every weekend.
All I know is it's annoying and I dont even feel like driving my truck. It pretty much just sits in the driveway and I have little faith in it.
Old Apr 18, 2007 | 12:01 PM
973604x4's Avatar
check any and all tie rods. i had 2 bad ties rods with very similar symptons.
Old Apr 18, 2007 | 01:19 PM
david_4x4's Avatar
Two different dealerships said that they were ok.
Old Apr 18, 2007 | 01:39 PM
Nate-03 D's Avatar
Hey David, whats going buddy?
The blue truck in my sig has this same issue, ever since the PS box quite and a new one was replaced. Before the box went out, it would do the same thing you are describing. We've check the tie rod, front end ect, and it all looks fine. We even put new bushings in the control arms. It still does it everynow and then.
I don't know what it is but it dosen't realy bother me that much, it's not my truck and I know mine dosen't do it.
You ever get that massive turbo installed?
Old Apr 18, 2007 | 03:12 PM
david_4x4's Avatar
Everything is good. Just wish I could figure this problem out.
Ive pretty much left the truck the way it is except for these springs and waiting on bumpers. After that Im pretty much done and everything will be stored or sold. Im pretty much burned out on this thing. I went from driving it 600 miles a week, now maybe once a week. Last time it got filled up was march 29th if that's any indication.
I have zero confidence in this thing until whatever is wrong gets figured out.
Old Apr 18, 2007 | 06:36 PM
nriver's Avatar
i am sure this is not it
but are the tires rubbing on something at full lock. Does this only happen while moving, or not moving. May help to eliminate some posible areas.
Old Apr 18, 2007 | 07:26 PM
zander79's Avatar
Mine had similar noises, turned out that my sway bar ends were hitting my coils. It sounded like it was comming from the steering, but it actually was not. Longer extensions solved the problem.
Old Apr 18, 2007 | 09:14 PM
Nate-03 D's Avatar
That sucks David, is it just the poping noise thats buggin you or is it multiple stuff, like the price of fuel? lol
Hit me up w/ a PM for what you want to sell, I may be interested in some stuff.
So what are you driving now?
Old Apr 18, 2007 | 09:27 PM
david_4x4's Avatar
Just this one thing is bugging me. Just because it's so minute and should be a simple fix, but a month later nothing.
If fuel price was an issue, the deuce and a half wouldnt have replaced the truck another daily driver. But it's the 2.5 ton or the 01 Mustang.
Sleigher
May 25, 2012 12:03 AM
M1AM14SPUR
Jan 8, 2012 06:17 PM
mstep3
May 16, 2009 07:30 PM
sheepdog
Feb 25, 2005 09:11 AM
MikeyB
Apr 8, 2004 05:21 PM
