Need help with backspacing and offset and some new wheels
Old Mar 6, 2007 | 11:17 PM
Lomarker's Avatar
Question Need help with backspacing and offset and some new wheels
Ok guys I needs some help understanding this whole backspacing and offset issue with wheels for my truck. I currently have the moto metal 951's, 17X9 with 4.53 backspacing and an offset of -12. I just got new tires today and went with the Toyo MT 295's and they still rub a bit...I wanted the 35's but there was no way they would fit with these wheels. I know plenty of people are running 35's with only the leveling kit. So my question is what do I need for wheels to run the bigger tires? More offset, less offset, more backspacing, less backspacing? I got little help from the tire folks and my searches here have resulted in some seemingly contradicting information. I am looking at the american racing Thugs wheels and they come in: an offset of 15 w/ 5 3/8 backspacing or -6 offset with 4 1/2 backspacing. Any improvement here? If not, what are some good offset/backspace number to look for. Thanks for any help.
Old Mar 6, 2007 | 11:31 PM
morkable's Avatar
The proper back spacing is over 6" and the offset is 25mm. Moto metals do not have a rim that is exactly the right fit for our trucks. I put on eagle alloys 0836 with 25mm offset. Fits perfect
Kevin
Old Mar 7, 2007 | 07:09 AM
Luvnacumns's Avatar
You definately want 6" back spacing..
Old Mar 7, 2007 | 12:43 PM
AZn8v's Avatar
Shane, how much backspace and offset do the Mako's have?
Old Mar 7, 2007 | 04:12 PM
ptgarcia's Avatar
A couple points I'd like to make:
1. Proper backspacing and offset changes with the width of the wheel. They are not constants.
2. Try to limit wheel width to 9". Anything wider typically leads to rubbing.
Refer to the following picture for an explanation of measurements. Pay particular attention to from what points rim width is measured, then compare that to where backspacing is measured from. There is a gap there. I usually estimate that gap to be 1/2", and that's usually close.
Old Mar 7, 2007 | 05:29 PM
morkable's Avatar
Im glad you chimed in Pauly, you are the local resident expert when it comes to rims
Kevin
Old Mar 7, 2007 | 09:39 PM
Lomarker's Avatar
Ok, that helps...so according to the diagram, how would have negative offset? Or positive? Thanks.
Old Mar 7, 2007 | 09:57 PM
Luvnacumns's Avatar
6" is what I measured..
Kevin
That is very true!!! Pauly is the man..
Shane
Old Mar 7, 2007 | 10:40 PM
ptgarcia's Avatar
Wow! I feel so loved
Offset is measure from the centerline of the wheel to the mounting surface of the wheel. If the mounting surface is outside the centerline (closer to the outside edge of the wheel) you have positive offset, and conversely if the mounting surface is inside the centerline (closer to the inside edge of the wheel) you have negative offset. Notice that backspacing can only be positive.
Old Mar 7, 2007 | 10:57 PM
Lomarker's Avatar
Gotcha, thanks fellas. The stock wheels were +42 and 6.1, thanks that what I read somewhere here??? and I went to -12 and 4.53, no wonder my combo rides outside the fenders. Again, many thanks.
Old Mar 8, 2007 | 09:12 AM
tcr's Avatar
tcr
Kevin
Kevin, What size tires/20s did you end up w/?
Jordan5687
Dec 12, 2010 11:08 PM
Redneck-Express
May 1, 2009 12:45 PM
Joe T
31
May 13, 2007 03:16 PM
Ramtough
Sep 2, 2005 01:04 AM
twvette
Jun 16, 2005 04:05 PM
