need fuel filter help?
Old Aug 26, 2012 | 11:48 PM
vctowpig's Avatar
I'm currently running a fleetguard fs1212 and a fleetguard ff5320 on the frame rails of my 05 with a wix in the factory housing. It's time to replace these and I was wanting a true 2 micron filter and a 10 micron f/w under the truck. I was looking at the fleetguard fs1000 but it's almost 10" tall and will hang too low. I couldn't find a length on the cat 1r-0750, but it looks too tall also. What do ya'll recommend? I've been looking online all night and can't find anything. I plan to replace the wix with the baldwin PF7977 but don't know what to do on the others. I felt like i needed a 10 micron in front of the 2 mic to help it last longer, or am i wrong? The fs1212 is a perfect fit and I know (from reading all the posts here) it's supposed to have one of the best f/w separators but felt like i needed a 10 mic instead of the 20.
Thanks
Trey
Old Aug 26, 2012 | 11:57 PM
vctowpig's Avatar
Also, how often do ya'll drain your f/w and do u do it while the truck is off or running? I've been running the fleetguard stratapore lf16035 oil filters. Is this the best oil filter to run?
Thanks
Trey
Old Aug 27, 2012 | 09:05 AM
vctowpig's Avatar
ok, got the 1r-0750 cat for the 2 micron. It's the same size as the fg ff5320. I was looking at the specs on 1r-0749.
I would still like to run a 10 micron f/w filter. Anybody know of one that is around 8" tall?
I can't find anywhere local to buy baldwin filters. Where are ya'll buying the baldwind stock replacements?
Thanks
Trey
Old Aug 27, 2012 | 08:37 PM
pull-do's Avatar
This is where I get my Baldwin filters,, also get the fleetguard air filter there also, I use the store off Navigation blvd. but they have other locations.
http://www.mddistributors.com/
Old Sep 8, 2012 | 05:44 PM
vctowpig's Avatar
thanks!
Old Sep 9, 2012 | 03:23 PM
C Schomer's Avatar
I use the OEM filter for a prefilter and water and a 2 mic after it. Craig
209trucker
Sep 22, 2013 11:35 AM
dieselfuelonly
Jan 24, 2012 10:16 AM
Doj Dewd
Aug 29, 2009 12:38 AM
Wildhog
13
Aug 4, 2008 08:07 PM
surfer5567
Nov 7, 2005 04:59 PM
