My truck is sick, i need some advice....
Old Oct 31, 2007 | 09:18 AM
bigman's Avatar
Last week i lost my glacier lift pump and as a result my truck started surging and missing and the two codes that it threw were 0148 rail pressure, and 0251 cp3 regulater. Thinking i toasted my cp3 i replaced both the lift pump and the cp3 with a new one and sent my original cp3 off to floor-it for there stage 2. Any way on the way to work today the same 2 codes came back, truck runs like crap and the lift pump is for sure working. I am not sure where to turn besides stripping my goodies off and heading to the dealer. Anyone have some ideas? Thanks Mark
Old Oct 31, 2007 | 09:28 AM
53 willys's Avatar
pick-up tube problem???maybe???
Old Oct 31, 2007 | 11:02 AM
cquestad's Avatar
Could be touching the floor of the tank?
Mark, Your truck is hard to diagnose when you don't have either a rail pressure gauge or a lift pump gauge...arhhh!
Old Oct 31, 2007 | 02:40 PM
jlibert's Avatar
fuel filter clean?
did the new cp3 come with a new fca or did you use the old one?
how did you verify that the new lift pump is working?
Old Oct 31, 2007 | 03:54 PM
bigman's Avatar
We used the old fca , the lift pump comes on and i can feel fuel moving down the line i am assuming being 3 days old that it works. Before anything i changed the fuel filter to see if it was something easy. I think its some electrical glitch i have a hard time believing that 2 cp3s in a row have gone bad.
Old Oct 31, 2007 | 04:29 PM
cquestad's Avatar
Dude...you did not tell me that...the FCA is most likely the problem.
Old Oct 31, 2007 | 05:12 PM
jlibert's Avatar
ouch! yep, try a new fca.
Old Nov 1, 2007 | 01:33 PM
yfz04drt's Avatar
My truck did the same thing. It was the solenoid in the FCA. My mechanic changed it out and truck runs fine now.
Old Nov 1, 2007 | 02:33 PM
kevins600's Avatar
John does work to the FCA I went to his shop while he did my stage 2 and when he reinstalled the CP3 it hit full rail pressure at idle. He messed with the FCA till it came down to normal operating pressure and we went for a ride to watch the pressures. a FEW, not all trucks he said react different to the modded FCA. You need to get a DRB or rail pressure gauge and check it out.
Old Nov 1, 2007 | 02:50 PM
stock600's Avatar
you calmly said you replaced the cp3, dealer said 4600.00 [i said no a inj. pump not a used truck or new engine] my question is why change the whole pump with all the talk of the fca being bad?
Old Nov 1, 2007 | 03:07 PM
bigman's Avatar
I assumed having driven around without a lift pump for a few days that i toasted my cp3. It was the glacier lift pump that i had installed in my truck that went bad, and it still seems fishy that the lift pump dies and now the fca goes bad at the same time. Anyway i am going to put a new one on this afternoon and see how it goes. I unhooked the edge ez yesterday and the truck ran fine for about 50 miles and then the same **** codes came back. The fca will go on the truck this afternoon and i will report back. John at floor it said that late 06s and 07s have some funny things happen that are hard to explain and diagnose. We will see.
Old Nov 1, 2007 | 03:36 PM
stock600's Avatar
ok , man thats not good, i hope you can replace the fca now and be back to normal, bad lift pumps have cost people a lot of money since 1999, wouldnt be cool if dodge recogized this problem and started putting a simple fuel press. guage from the factory even an idiot light, just the thought from dodge would be neet. dont make sense to me, they started using the wrong style pump in 99 and knew it but cont. till 05, it must have cost them a fortune. i do think this in tank is a lot better pump if dodge or truck owners would all install a 0-15 guage and once in a while check, but even better go back to the mech. pumps and still a guage. dont hear this same prob. from the 12 valve guys, and it runs off the eng. needs of rpm, wonder why they changed, just a thought.
Old Nov 1, 2007 | 09:20 PM
bigman's Avatar
Replaced the fca, not abit of differance. Runs like crap and still throwing codes. How could a lift pump failure cause so much trouble esp. after replacing the cp3. Rail pressure guage is next i guess. Man i love fiddledickin like this
Old Aug 24, 2009 | 10:05 PM
shane mac's Avatar
my truck has p0088 and 0251 codes tried fac and rail pressure sensor just wondering what you problem was if you got it fixed.
thebanker
Apr 2, 2013 11:51 PM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
bsj04
Sep 20, 2007 08:09 AM
ryan466
Aug 30, 2006 10:10 AM
Brad02ctd
Mar 3, 2006 08:29 AM
