Are my egts to high
Old Mar 22, 2007 | 12:40 PM
dirt's Avatar
Are my egts to high
Just wondering if my egts seem alittle high for a totally stock truck?
at idle around 400* zero boost
cruzing 600-800* 5-15lbs boost
punching it wot 1200-1300* 30lbs boost (egts spike and fall off a bit)
Also it seems like the air box is quite restrictive as the filter minder is always sucked all the way in.
T.I.A Paul
Old Mar 22, 2007 | 12:41 PM
dodgezilla04's Avatar
no, the CR motors run hotter egt's due to an extra late injection event intended to keep the catalytic converter at the proper temp. dont worry, sounds about like mine did when stock. think that's warm? add some extra fuel!
Old Mar 22, 2007 | 12:47 PM
madhat's Avatar
Administrator/Jarhead
^^^x2 I see that on stock settings. If you do not want to spend big bucks on a CAI, do a serch on DIY air box mods...
Old Mar 22, 2007 | 12:48 PM
ptgarcia's Avatar
Those temps look just like mine, Paul. And my filter minder was always sucked in also, until I replaced the filter with an Amsoil EAA189 drop-in. If you don't want to do the whole intake the Amsoil drop-in filter is a good alternative.
Old Mar 22, 2007 | 01:02 PM
dirt's Avatar
Thanks for the quick replies.
It kind off made me think twice about wanting a box or programer.
Paul
Old Mar 22, 2007 | 01:49 PM
white06's Avatar
i think if you straight pipe it your temps will drop a bit . mine did atleast . mine at idle are around 250 or so .
Old Mar 22, 2007 | 02:27 PM
ptgarcia's Avatar
Mine will drop to 250* idling in park, but let it idle in gear and its about 405*.
Old Mar 22, 2007 | 03:21 PM
white06's Avatar
i am guessing the 6 speeds are different ?
Old Mar 22, 2007 | 03:24 PM
ptgarcia's Avatar
Probably because there is no load on the engine with the manual in neutral or the auto in park. No load will equal lower EGTs. Put the auto in drive and put the brake on and there's a load on the engine (torque converter) and higher EGTs.
Old Mar 22, 2007 | 03:41 PM
qzilla's Avatar
Throw a Boost fooler on there and I promise they will drop at least 100 deg at WOT. Well worth the money for the egt drop and it is considerably cheaper than an intake or anything else.
Old Mar 22, 2007 | 05:08 PM
Mixer Man's Avatar
Just installed one last night on my beast works perfect with my Predator !!!!
Awesome product there Quad , I am definately happy !!!
lgp9999
Sep 8, 2007 11:19 PM
Bradleysram
32
Nov 25, 2004 09:25 AM
BCarmicle
Sep 22, 2004 12:10 PM
Towrig
18
Jul 16, 2004 02:34 PM
NOTSTK
Aug 9, 2003 09:10 AM
