Manual to Auto Conversion COMPLETE
Old Sep 12, 2007 | 09:42 PM
livingez_123's Avatar
Any updates to this?
Old Sep 12, 2007 | 10:33 PM
tweeter's Avatar
Jeff K's gallery is great, but you need to see that truck in person. Jeff doesn't do anything halfway, and his truck is absolutely amazing. Top notch work on everything, he'd need about 5 signatures to list all of the stuff done to that bad boy. Cheers, buddy, nice work. Marc
Old Sep 12, 2007 | 10:43 PM
jwb600's Avatar
I dont think it was a bad move. the manual trannys are getting hard to find and very expensive it looks like. so at least you can buy parts for your built auto if something happens
Old Sep 12, 2007 | 11:29 PM
Jeff K's Avatar
Thanks Marc!
The auto is working great. No problems at all so far. I am in the process of wiring up a few more switches into the tranny controller so I can select between the two calibration files, lockout OD, and select manual mode. I also am wiring up a circuit that will allow me to use the steering wheel volume controls for the upshift/downshift while in the manual mode. Should be sweet!
Old Sep 13, 2007 | 01:41 PM
SSminnow's Avatar
Originally Posted by Jeff K
Thanks Marc!
Are talking about a Paddle Shift type of setup? I guess with those long Canada winters you have some extra time on your hands
Old Sep 13, 2007 | 02:25 PM
Jeff K's Avatar
Yup, the ATS standalone controller has provisions for wiring in the multiplexed steering wheel volume control button signal so that you can use those buttons for upshift/downshift.
A heated garage + A long cold Canadian winter = lots of time spent playing with the truck
Old Sep 13, 2007 | 02:31 PM
SSminnow's Avatar
That's cool, I like your setup. Why did you choose to go floor shift? So you would not have to swap out columns?
Old Sep 13, 2007 | 03:00 PM
supercharged_hp's Avatar
If you don't want to lose your volume controls, companies like Twist Machine make aftermarket paddle shifters as well. Might be tough to work it into the factory steering column but what else can you do in the winter.
Your truck sounds like it belongs on the cover of a diesel mag
Old Sep 13, 2007 | 03:36 PM
Jeff K's Avatar
Yeah, i didn't want to deal with the hassle of removing and replacing the column, so I went with the floor shifter. I also already had the hole in the floor and the floor console, so it just made sense to me.
Supercharged_hp, Thanks for the comments I will look into those paddles and see if the could work. Right now, I am planning a relay driven circuit that would route the steering wheel volume button signal to the tranny controller when I am in manual mode, and still be used for volume otherwise, but dedicated paddles would be pretty cool!
Old Sep 13, 2007 | 04:12 PM
matego's Avatar
madhat's monkey boy...
Jeff K, I hope you will be around to answer a few questions because I think I am going to do the same thing. I am into drag racing and the manual is not cutting it. I have to unload the manual to help fund the project, but it looks like it shouldnt be that bad. Your installation looks awesome. It really pays to take your time and do it right.
Old Sep 13, 2007 | 06:13 PM
Jeff K's Avatar
Matego, I am usually lurking around these forums most days. Feel free to shoot me a PM if you have any specific questions.
Old Sep 13, 2007 | 08:55 PM
SSminnow's Avatar
That ought to be real cool when completed, and something that you could probaly market once completed. I am sure ALOTof guys here on the site with autos would like a paddle shifter type setup. Since I brought it up however, I get 10%
Old Nov 21, 2019 | 01:59 PM
Troy Zeller's Avatar
ATs lock up controller
Would the ATs lock up controller and select shift work on an already built stage 3 ATs automatic tranny?
horselady
May 27, 2011 09:19 PM
Bobcat698
26
Aug 1, 2006 11:38 AM
Mechanos
Jan 11, 2006 08:56 PM
richard
Nov 3, 2005 05:15 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
