Looking for gauges, Who's are the best for the buck?
I have been looking for a gauge set for my 03 3500 and wanted something that was a all in one. samll and digital. Thoughts??
Thanks
R
Thanks
R
I have a Quadzilla Commander (which you can get here pretty cheap) and I'm pretty happy with it. I have the rail pressure and fuel pressure add on kit, and the mount that goes on the pilllar with the grab bar (which looks clean). You can check it out at quadzillapower.com
Commander if you want to view up to 4 parameters at once, and monitor up to 7.
Quadzilla Recon if you only need the basic three parameters and can live with only being able to view one value at a time. Very small unit.
There are others but I consider them overpriced when compared to the Quad products.
The Recon is pretty cheap and easy to install. It can monitor 4 parameters (only one at a time though): boost, EGT, trans temp, and fuel pressure (with added FP kit).
I like my gauge set for being cheap and easy but it does suck to have to switch between parameters. On the other hand, it's nice because it doesn't stick out too much and you can mount it in a subtle location. I have mine to the right of the parking brake release.
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
Kuntry
06-19-2005 05:14 PM
