Installed new remote starter with 15 second delay...
Old Nov 22, 2006 | 08:06 PM
dieselnewbie's Avatar
instead of wiring directly to the grid heater ready status (where ever that is...).
I had them set a 15 second delay for the grid heaters to do their thing.
Has 15 seconds proved to be enough of a delay for you guys in colder climates?
I can set it to 20 seconds and that seems very long, but I estimate 15 sounds OK for say...0-10*F in the morning.
That sound right?
Any response will be appreciated.
Thanks,
DT.
Old Nov 22, 2006 | 08:17 PM
mudslinger's Avatar
The wait to start only stays on for about 13 secs. even in the cold. I have used the 15sec. delay without issue personally. Hope this helps.
Old Nov 22, 2006 | 09:14 PM
Thanks Muddy!
What kind of cold are you talking about?
We usually get a few consectutive weeks of 0-single digits around here in January.
I don't think I've ever seen that wait to start light stay on for more than 15 seconds but I've never timed it.
Thanks again,
DT.
Old Nov 22, 2006 | 09:22 PM
ptm600's Avatar
Mine is generally on for 10 to 13 seconds in the temps you're looking at. Last winter while sledding in quebec at -20f it stayed on for about 35 seconds. So if you do have a real cold snap it may stay on longer.
Old Nov 22, 2006 | 09:50 PM
Smokeman's Avatar
I think you'll be fine with 15 seconds. Thats what I use as well.
Old Nov 22, 2006 | 09:56 PM
rjelliott's Avatar
What brand of remote start are you using. I would like to install one but have not started looking yet.
Old Nov 22, 2006 | 10:47 PM
It's an Audiovox Pursuit, model #9775T
WOrks good so far.
They did have a problem though. Originally the hooked it up to read back batter voltage. Reading this allows the unit to determine when the truck is actually running so it can turn off the starter.
That didn't work too well so they found another signal (a pulse) to plug into a tach sensor to determine the when it's running.
So far so good tho.
Check it out:
http://www.audiovox.com/webapp/wcs/s...3430&langId=-1
Good luck,
DT.
Old Nov 22, 2006 | 10:51 PM
rjelliott's Avatar
Thanks for the info.
Old Nov 23, 2006 | 06:39 AM
mudslinger's Avatar
hey newbie, I think our winter temps are pretty close. I have auto started from those temps many times without issue.
Old Nov 23, 2006 | 09:46 AM
STATELINE's Avatar
you might want to check this one out, http://www.blackwidowsecurity.com/x5.htm
it's what I got for mine, not installed yet, but feature loaded, security system, remote start, & turbo timer all together. priced right too. got mine at etronics.com
Old Nov 23, 2006 | 12:43 PM
XLR8R's Avatar
The remote start unit doesn't allow the ECM to power the grids as it sees fit?
Old Nov 23, 2006 | 02:52 PM
Jfaulkner's Avatar
Muted User
Almost all remote starters have a "glow plug" wire, however dodge doesn't have a wire that it can be hooked to since the dash on the 3rd gens are data controlled. So you either have to soldier it directly to the "wait to start" led in the dash (which is a huge pain) or use a delay timer (which most starters also have). You may be able to hook it directly to the grid heater relays however they cycle on and off while the truck is running so I'm not sure if this will cause the remote starter to shut down or not. (haven't had a chance to try it yet).
I've done probably 100 of them in the past few years and I've always had good luck with Crimestopper, CodeAlarm, and UltraStart (manual trans). Reguardless of brand I recommend one with a "2-way" remote. That way if your in a resturant or at work and you want to start your truck you don't have to be able to see it to know if your in range or if it started, the remote tells you.
Mine is set for a 10sec delay and it's never been a problem.
Old Nov 23, 2006 | 03:41 PM
mudslinger's Avatar
I have a Black Widow that I am swapping over to the new Viper 5900, I have installed the last generation of both companys a few times at least, both seem to get the job done. I definately backup the statement to go with 2-way though, makes a huge difference.
Undertaker
Oct 26, 2009 03:02 PM
AllanP
Feb 20, 2009 07:15 AM
buckman361
Nov 13, 2008 09:54 AM
4x4dually
Oct 19, 2006 08:31 AM
Idaho Guy
Nov 19, 2004 06:45 PM
