Installed injectors = start delay
Old Feb 18, 2009 | 11:18 PM
AllanP's Avatar
I installed stage 2 injectors and now I have a delay when I start the truck. I have to turn the key on and wait about 5 seconds and then the truck starts right up. I can turn the truck off and immediately try to start it but it will just turn over unless I wait the few seconds. I also replaced all the orings on the injectors and cross over tubes.
Any freakin ideas?
The heads clean no fuel leaks. I even turned it off and pinched the fuel line in case fuel was running back to the tank. Still does it.
Old Feb 19, 2009 | 01:01 PM
BigErksG2's Avatar
the higher pop off pressure might cause this. try starting it with a little pedal.
Old Feb 19, 2009 | 07:15 PM
97 D-Tec's Avatar
Who are they from?
Old Feb 20, 2009 | 07:15 AM
EBunger's Avatar
Make sure they are torqued to 89in/lbs or the copper washers will leak and that will cause it to.
GSP7
Dec 25, 2013 08:25 AM
dieselnewbie
Nov 23, 2006 03:41 PM
Jack Thorpe
Nov 6, 2003 01:25 PM
