how much rail presure is too much??????
since adding the stage 3 pump and cam i got a dr p box and uploaded pl tune on my triple dog. at idle i see 8800-9200 rail pressure. it idles real rough and choppy and i dont know if its due to the high rail pressure or what. just cruising it sets mid 26's. at full throttle it will drop to about 24000 for less than a second then ramp up to and hold between 26800-27200. is this too much rail pressure? thnks ahead of time
What stg3 you running, Mine doesnt run rough at all, pressure is a bit more at wot, and normal driving is less thin 24k are you running the dr p all the time all the way up? pressure is bad all the time, over time,. Im not sure about the rough idel, may be FCA
I won't say its bad to run with pressure, you just need to tune your pressure to certain psi while drivin mainly, keep your pressure down to 15-19k while cruising. Your wot looks good, and idle looks good, but if you're cruising 26s that's bad, thats about what you want max period, even at wot.
When I seen the title on this thread all I could think about was,,,, when the needle starts to bend its too much,, lol. But really all I can see wrong with yours is your crusing number
Kevin
Kevin
thanks for all the reply's guys. I'm running the II stage 3 with a dual feed line. The dr performance box i'm running is model 2025 they said it was for off-road use only, i really don't know? I have a toggle switch for it but i can only turn it on or off i cannot turn it down. With pedifile larry if i dont hae it on the truck will throw codes. With just the pressure box it runs around 23-25000 but when i adjust on the fly to p/l the pressure is high like i stated all the time. i can say this on the way home from work today on the highway i rolled into the throttle on the entrance ramp then hammered it and all i can say is it got it on! the pull is amazing on the top end, i can't wait to get this thing to the track. I am sure my stock injectors are gonna be junk soon so a set of don's stix are in order. With the set-up in my sig what do you guys think my pump and turbo can handle? i got it narrowed down to something in a 2.5-3.5 i just don't know where in that range would be right for me without causing too much heat or making the pump run down. thanks again everyone and sorry for the long post
bigjohn04
Feb 3, 2009 09:21 AM
incognyto
Nov 22, 2008 01:27 PM
BossHogg
Oct 24, 2008 09:54 AM
