Hooking fuel pump directly to CP3
I was wondering when i install my raptor 150 im going to elimnate the stock fuel canister, so how do i go about hooking it up directly to the CP3. i see on the CP3 what theres 2 lines going to the fuel canister what do i do with them
thanks,
matt
thanks,
matt
you will need a GDP filter eliminator bracket if you want to remove the stock filters...the metric AN adapter that came with the raptor should screw into the CP3..you may or may not have all the fittings you will need supplied with your Raptor..but I think you can make it work..if any thing you will have some left over fittings I would think....
you could buy some new o-ring washers..but you may not need them..I just reused mine..other then that, that's all you need for the GDP bracket.
RyeThomas
Jul 26, 2007 10:30 AM
Dodgezilla
20
Jun 12, 2006 04:32 PM
