First time on a dyno...
Well my friend invited me to go to a dyno meet and convinced me to make a few runs. I just ordered a smarty jr.(very excited about) and will probably run the medium 70 hp tune. Not wanting to even try the 100 hp for fear of loving it and slipping the very stock TC. Was wondering if there are any things i need to check and/or advice? All fluids were just replaced over the past few weekends. Its a major noob question but only one way to learn...
I would just make sure its at operating temperature before they pound on it. I like to let my truck run before they dyno it but I dont rev it up a thousand times either just let it run for min beforehand is what I do. I would shut your O/D off it maybe easier on the converter
Guessing cruise through the gears, and get agressive once it hits third and go WOT once the TC locks into OD??? kinda confusing, im sure i can talk to some peeps there but trying to get some info here so i dont look like a total idiot.
Its alot easier when the engine is out of the application. I get to see Cat engines on the dyno whenever i want.
I to went to my first dyno deal this past weekend it was a lot of fun. The stick trucks no prob. stick it in 6th load the moter and go for it, but the guy operating the dyno was having issues with some of the autos. He would ease them up through the gears and whack the throttle to early and it would downshift, he'd let off and do it again, i quess finally untill he had enough wheel speed to where it would not come down a gear. I stopped on the way and got a good shot of injector cleaner for good measure.
AKRAM had very specific instructions I remember reading, I just do not remember which forum, I am sure if you did a search you could find it.
I also tried dragging my brakes to load the motor, all that acomplished was unlocking my tc.
Dyno runs are the perfect use of the LockUp switch being added to a truck. If you search around the forum you will find lots of info on how to install a lockup switch for different models of trucks.
Once the truck is in OD turn the switch on. It prevents the truck from down shifting and keeps the lockup on. You need to turn the switch back off before bringing truck to a stop or it will stall the truck.
I am thinking of adding this just for Dyno use...
Most people say you're supposed dyno an auto in 3rd because that's the 1:1 ratio. I think dyno'ing in 4th would be the one that's a waste of time because the numbers would all be skewed.
