holding brake during spool up with automatic?
Old May 18, 2008 | 09:19 AM
kyle_truck_pull's Avatar
Exclamation holding brake during spool up with automatic?
when you hold the brake when u spool up with an auto to build boost, does it hurt the tranny any?
Old May 18, 2008 | 09:23 AM
annabelle's Avatar
Sure, it may cause slipage.
Old May 18, 2008 | 11:02 AM
johnh's Avatar
if you do it very long, you could burn it up. when we did a tune on a gasser we would do a "stall" test to check the rpms and the condition of the trans/converter. you cannot exceed 250 degrees trans oil temp...... doing a stall raises temps FAST!
Old May 18, 2008 | 01:51 PM
thanks for the info, how long is to long?
Old May 18, 2008 | 01:52 PM
2007 5.9's Avatar
Get a trans temp gauge hooked up in the "HOT" line and then you will know....prob no more than 5-10 sec.....
Old May 18, 2008 | 02:12 PM
Gary Emerald's Avatar
watch your tranny gauge
Old May 18, 2008 | 05:17 PM
omaharam's Avatar
I wouldn't be worried about clutches. I'd be worried about a broken shaft.
Old May 18, 2008 | 06:51 PM
u dont think it will hurt the clutches? i know a lot of auto truck do it before a pull to build boost i thought. or like right before you do a big burnout. i just dont want to ruin my tranny.
Old May 18, 2008 | 09:10 PM
05ChainSmoker's Avatar
whats all done to your tranny
Old May 19, 2008 | 05:46 PM
it been redone by BD transmisions, im not sure what all is done to it. but i do know im real herd on that truck and i havent had no tranny problems yet. the tranny also has a BD pressure lock on it too. it just doesnt have a valve body yet. thats what i want to do next.
Old May 19, 2008 | 06:01 PM
jrussell's Avatar
I have a fast responding gauge in the hot line and mine doesn't seem to get any hotter if I stage for 15 seconds or if I stage for 5. It will see around 200* at the end of a 1/4 mile run in 90*+ temps.
I ALWAYS stage last at the track so I don't have to hold boost while the other guy stages. You see videos of high HP guys staging for 10-20 seconds and they don't seem to be doing any immediate damage.
Old May 19, 2008 | 08:25 PM
i would say if you get a good valve body and converter which you might already have the converter im not really firmiliar with your tranny you would be fine with boosted launch's
Old May 19, 2008 | 08:47 PM
thanks guys, all this info really helps. this is my first automatic so im not sure about what they can take. i have had a 6 and a 5 speed before and they were tuff, but i did break shafts. how many degree temp gauge should i get? i guess i can look online and see what they sell.
dieselcarpenter
Apr 27, 2013 06:02 AM
joem
Feb 13, 2012 04:58 PM
learners_permit
Jul 31, 2007 05:05 PM
Kent
Jan 5, 2003 08:54 PM
