Has Anyone Had Warranty Voided For Pyro?
Old Oct 4, 2006 | 11:04 PM
pet05's Avatar
I am just curious if anyone here had there warranty voided due to them having a pyro installed OR if they had pipe plug on the manifold with NOTHING installed. (AKA-removed box before taking it to the dealer)
Can the dealer void your drivetrain warranty due to a pipe plug (where the pyro used to be) in the manifold?
Old Oct 4, 2006 | 11:17 PM
stock03's Avatar
I don't think so. I guess if they can prove your pyro caused the warranty issue. I would leave the pyro.
Old Oct 5, 2006 | 01:38 AM
Syndicate's Avatar
only the warranty on the manifold.
Old Oct 5, 2006 | 06:14 AM
sadlerb_98's Avatar
My dealer doesn't care if one has gauges. The didn't give mine a second look. Now a box is something different.
Bob
Old Oct 5, 2006 | 06:19 AM
deezulsmoke's Avatar
A lot of dealers wont warranty the turbo if the pyro is before the turbo in the manifold. If anything ever happens to the probe in the manifold you can kiss your turbo good-bye. But you get the most accurate readings out of the manifold also.
Old Oct 5, 2006 | 08:22 AM
stock03's Avatar
Has anyone lost a turbo due to a pre-turbo pyro breaking?
Old Oct 5, 2006 | 09:38 AM
53 willys's Avatar
I don't think it's ever happened.
Old Oct 5, 2006 | 11:43 AM
Diesel-Dan's Avatar
I would bet more of a big truck issue years back with inferior material being used for the probe. I would think after a certain amt of time the heat cycling would be an issue. And these would be treated as a maintenance item BUT big trucks count miles in the Millions……….. Our trucks…..i wouldn’t even 2nd guess my probe.
Old Oct 5, 2006 | 11:47 AM
Patrolman808's Avatar
Most big trucks run them after the turbo nowadays, or all of the ones I've seen do.
Old Oct 5, 2006 | 11:52 AM
wagonhauler's Avatar
If you look at the cummins warranty book you can get voided for nearly anything. You can even get voided for not using an approved filter. I will look at work (I work for a cummins dealer) today and see if i can find something to post. Also if they will void your warranty for a pyro, why is there a pyro you can get through mopar acessories.
Old Oct 5, 2006 | 01:05 PM
ptgarcia's Avatar
Every vehicle manufacturer puts the same statement in their manuals about voiding warranties if you add anything to the vehicle. They have to to protect their *****. But having a pyro probe won't void anything unless it breaks and goes through the turbo.
I'd leave the probe in. I would think a bolt in the manifold would throw up more red flags than a pyrometer.
Old Oct 5, 2006 | 02:01 PM
TonyB's Avatar
Keep in mind the dealer may void the warranty. However, the Magnusson Moss Act requires them to PROVE the part you instaled caused the damage you are trying to warranty.
Unfortunately, you usually have to get a lawyer involved to force them (DC/Dealer) to comply with the Magnusson Moss Act.
HTH
Tony
sr148
57
May 10, 2007 11:02 PM
cromulius
Aug 13, 2006 09:53 AM
tanderson2002us
25
Apr 18, 2006 11:08 PM
jefe4x4
14
Jan 16, 2005 01:55 AM
TXSST
May 24, 2003 02:35 PM
